I want to get a Thermapen.  Which one should I get?
Also, will this work to measure of the surface of the pan?  If not, what works best for that?  Infrared thermometer?  What kind?
[I need to start cooking again or else I am going to turn into a blimp.]
Edited by shellylh
I've never worried about the temperature of the surface fo the pan.  As to which thermapen, the cheaper one is good enough unless you can't wait a couple seconds
6 hours ago, EdipisReks said:
Once you push past the leidenfrost effect
Never heard of the leidenfrost effect until now, and had to look it up.  Although it is clearly the correct name for when I could plunge my hand into a bucket of liquid nitrogen for half a second without ill effect.
