hausera Posted November 3, 2015 Report Posted November 3, 2015 (edited) Hello,I'm new to audiophile headphones and I mean completely. I bought based upon recommendations on various websites an Aune X1S. I play Spotify with my iPhone 6 and sometimes my Mac. I understand that I can use an RCA cord to do analog. I want to know how I can connect it digitally? I read that I need an Apple lightning camera connector. Is this the one? Here is the back of the Aune X1S: Thanks for any help that you can give Edited November 3, 2015 by hausera Quote
swt61 Posted November 3, 2015 Report Posted November 3, 2015 (edited) The plug goes in your Aunes. Twist it around a few times for the best fit. Edited November 3, 2015 by swt61 Quote
acidbasement Posted November 4, 2015 Report Posted November 4, 2015 JH13 goes between the iPhone and the aunes. Obviously. Quote
grawk Posted November 4, 2015 Report Posted November 4, 2015 they definitely matter less now that there's bluetooth, but most bluetooth audio isn't good Quote
wink Posted November 4, 2015 Report Posted November 4, 2015 Sell the lot and get the new Sennheiser Orpheus Quote
Grand Enigma Posted November 4, 2015 Report Posted November 4, 2015 Are there other ones it could be? Quote
grawk Posted November 4, 2015 Report Posted November 4, 2015 I don't think the lightning to SD adapter will do what you want it to do. It's possible the lightning to usb camera connection cable will, however, and you should definitely try it. Quote
wink Posted November 5, 2015 Report Posted November 5, 2015 To connect digitally, use your fingers....... or, if very desperate, you can try your toes..... 1 Quote
en480c4 Posted November 5, 2015 Report Posted November 5, 2015 A real response? AppleTV.I use one at work where I can't connect to a Wi-Fi network. The beauty of the AppleTV is that it uses Bluetooth to proximity-locate the iPhone and then does a kind of local Wi-Fi connection between the two to allow for lossless AirPlay streaming. You would then connect the optical out of the AppleTV to the optical input. I picked up a refurb for $50, have it connected via the optical out to my DAC and then to my Quad 9L Active speakers. Lossless digital connection and wireless, too.Just in case someone is looking down the road. 2 Quote
