johnwmclean Posted December 29, 2016 Report Posted December 29, 2016 I’ve had yet another terrible experience with Cam-Expert, a relationship of years has come to a head after getting back a front panel for the second time that was very poor workmanship indeed, the brushing was coarse and rough, the rear side screw holes for the stax sockets were still slightly out of alignment again (I managed to fix this by making the holes slightly bigger on the sockets themselves). Anyway... I did a bit of experimenting, I removed the anodising via a caustic soda bath and wet sanded for a brushed polished look. I did this for all panels, the result isn’t bad and I prefer the shiny appearance to the duller clear anodised panels, but it does leave the panels vulnerable to fingerprints and scratches easily. Here’s a pic of the results... 4
bui501 Posted December 29, 2016 Report Posted December 29, 2016 So... Having completed by first KGSSHV build using boards from Spritzer, I'd like to move on to a KGSSHV Carbon build. I've already had the carbon amp boards fabricated using the gerber files on Dr. Gilmore's site. I'm puzzled as to which of the myriads of power supply boards I'll need to power the carbon amp boards, however. My KGSSHV build was an on-board version -- I'd like to go with an off-board version for the carbon build. Would some of the more experienced members give me some tips on which power supply boards I can use and any gotcha's to watch out for with a carbon build? -Vinh
johnwmclean Posted December 29, 2016 Report Posted December 29, 2016 The Carbon is purely an off-board build btw. The 2 power supplies; 1) The Golden Reference High Voltage (GRHV) these boards include bias and low voltage circuits. 2) The Golden Reference Low Voltage (GRLV) supplies. You need to chose between using the the supplied low voltage circuit included on the HV boards or use a GRLV. If you do use the low voltage circuit included on the HV boards you won't need the GRLV boards. I personally like the GRLV supplies and think they are worth it, YMMV. From here... the many gerber files are mainly sizing and split supply options, most of them will be a choice purely to suit your design requirements. Watchouts... Well I prefer stainless steel M3 socket screws for the cree and ixy devices, many builders here use peek screws, I haven’t had anything arc yet, just be diligent and ensure work is clean and solder joints are as smooth as possible. I completely flush the scrub boards with 99% isopropyl alcohol before powering up. 2
JoaMat Posted December 29, 2016 Report Posted December 29, 2016 Has anyone tried the low voltage supplies on the HV boards with AMB’s Sigma 78/79 regulators? I think it would be a simple and not very expensive improvement.
HemiSam Posted December 29, 2016 Report Posted December 29, 2016 16 hours ago, johnwmclean said: I’ve had yet another terrible experience with Cam-Expert, a relationship of years has come to a head after getting back a front panel for the second time that was very poor workmanship indeed, the brushing was coarse and rough, the rear side screw holes for the stax sockets were still slightly out of alignment again (I managed to fix this by making the holes slightly bigger on the sockets themselves). Anyway... I did a bit of experimenting, I removed the anodising via a caustic soda bath and wet sanded for a brushed polished look. I did this for all panels, the result isn’t bad and I prefer the shiny appearance to the duller clear anodised panels, but it does leave the panels vulnerable to fingerprints and scratches easily. Here’s a pic of the results... Sorry to see the trouble with your vendor, John. Must say the result does look very good to my mechanically inclined eyes. I have quite a bit of experience with raw aluminum on my car projects and your conclusions are spot on...high maintenance to say the least. Anodizing or powdercoating (if you can find one that scratches the itch) is best in the long run IMO. Regardless, your work continues to impress. Happy Holidays! Sam
bui501 Posted December 30, 2016 Report Posted December 30, 2016 20 hours ago, johnwmclean said: The Carbon is purely an off-board build btw. The 2 power supplies; 1) The Golden Reference High Voltage (GRHV) these boards include bias and low voltage circuits. 2) The Golden Reference Low Voltage (GRLV) supplies. You need to chose between using the the supplied low voltage circuit included on the HV boards or use a GRLV. If you do use the low voltage circuit included on the HV boards you won't need the GRLV boards. I personally like the GRLV supplies and think they are worth it, YMMV. From here... the many gerber files are mainly sizing and split supply options, most of them will be a choice purely to suit your design requirements. Watchouts... Well I prefer stainless steel M3 socket screws for the cree and ixy devices, many builders here use peek screws, I haven’t had anything arc yet, just be diligent and ensure work is clean and solder joints are as smooth as possible. I completely flush the scrub boards with 99% isopropyl alcohol before powering up. Thanks, John. I'll go with the GRLV. Much appreciate the tips.
bui501 Posted December 30, 2016 Report Posted December 30, 2016 Thanks, John. I'll go with the GRLV. Much appreciate the tips.John, I found the Goldenreference7plus and goldenreference7minus boards--they look like just the LV version you've mentioned. Which ones of the boards is the GRHV board?Sent from my iPhone using Tapatalk
johnwmclean Posted December 30, 2016 Report Posted December 30, 2016 Split HV Boards as follows: The skinny boards kgsshvpssicfetsinglenewrightsws.zip kgsshvpssicfetsinglenewleftsws.zip The fat boards HV kgsshvpssicfetsinglenewrightfatsws.zip kgsshvpssicfetsinglenewleftfatsws.zip bui501 I have a stash of boards, every option fat, skinny dual... just pm me for a price.
Whitigir Posted February 7, 2017 Report Posted February 7, 2017 Hello all, it is my first time here and as I am very interested in building myself this Amp, this is my first post. I am looking into buying the boards, chassis, volume controls and PsU to start the motion. Can someone point me to where to get it ? Thank you just pmed John above. Hopefully to hear good news soon 1
purk Posted February 8, 2017 Report Posted February 8, 2017 21 hours ago, Whitigir said: Hello all, it is my first time here and as I am very interested in building myself this Amp, this is my first post. I am looking into buying the boards, chassis, volume controls and PsU to start the motion. Can someone point me to where to get it ? Thank you just pmed John above. Hopefully to hear good news soon Hi Vince, You are in good hands. John's DIY work is very inspiring.
wink Posted February 9, 2017 Report Posted February 9, 2017 (edited) Vince, John is a meticulous graphic artist and builder. Below is a Carbon designed and built by John, sitting on top of a KGSSHV off board designed and by John and assembled by me. The knobs are stainless steel on the Carbon and titanium on the KGSSHV... Edited February 9, 2017 by wink Extra info. 5
Pars Posted February 9, 2017 Report Posted February 9, 2017 On 2/7/2017 at 11:14 AM, Whitigir said: Hello all, it is my first time here and as I am very interested in building myself this Amp, this is my first post. I am looking into buying the boards, chassis, volume controls and PsU to start the motion. Can someone point me to where to get it ? Thank you just pmed John above. Hopefully to hear good news soon I think he said HE was going to build it, not John...
drmlyung Posted February 19, 2017 Report Posted February 19, 2017 (edited) I would also very much like to try my hands on building the Carbon. +1 PM John. Edited February 19, 2017 by drmlyung missing words
JoaMat Posted February 22, 2017 Report Posted February 22, 2017 Needs more work - a lot. Board size 4.5 in x 2.4 in. No trimmers, servos on bottom. 6
drmlyung Posted February 23, 2017 Report Posted February 23, 2017 On 4/3/2016 at 5:05 AM, congo5 said: looks to be 5" x 2.5" Would like to use this on my Carbon build. Is there a way to get the schematic and BOM?
Kerry Posted February 23, 2017 Report Posted February 23, 2017 These boards have extra circuitry for the delay timer, which is not needed on the Carbon. I'd have to see if I can dig up a bom. Not sure if I published it earlier.
joehpj Posted February 24, 2017 Report Posted February 24, 2017 (edited) This is a small project paying tribute to stax mafia. So I called it stacked mafia. I am going to build several amps in the same boxes. This is the first one. The Carbon with two boxes, GRHV, GRLV, 23 stepped VR. Planned by my friend and I and built by @ang728. Here are some pics. One GG is also done and more amps are in progess. photo credit to ang728 Edited February 24, 2017 by joehpj 8
congo5 Posted February 24, 2017 Report Posted February 24, 2017 (edited) That looks great, very much like the looks, the clean rounded face and color, the lettering and ventilation Edited February 24, 2017 by congo5
johnwmclean Posted February 24, 2017 Report Posted February 24, 2017 (edited) Very nice building. I can't see any thermal grease applied? Not sure about those insulators with metal screws? Edited February 24, 2017 by johnwmclean
ang728 Posted February 24, 2017 Report Posted February 24, 2017 (edited) On 2017/2/24 at 3:46 PM, johnwmclean said: Very nice building. I can't see any thermal grease applied? Not sure about those insulators with metal screws? I'm not applying too much thermal grease on ceramic thermal pads and angle brackets but sufficient to have good thermal contacts My approach is applying thermal grease at about pea size then screw all the compoments together,let the pressure spread out the grease. Edited February 27, 2017 by ang728 1
drmlyung Posted February 24, 2017 Report Posted February 24, 2017 On 2/22/2017 at 7:53 PM, Kerry said: These boards have extra circuitry for the delay timer, which is not needed on the Carbon. I'd have to see if I can dig up a bom. Not sure if I published it earlier. Hi, Kerry, Thank you for the quick reply. You did mention in the previous post that " Just don't add the opto relay (CPC1117N) and the 600 ohm resistor (not necessary). It is a normally closed relay that prevents the HV from starting up. EDIT: Also, the 3K resistor above the relay is not required." I have gone through every page of this thread, couple of times, and could not find the BOM (or its location) nor the schematic. It would be great if you could provide a pointer.
congo5 Posted February 24, 2017 Report Posted February 24, 2017 (edited) On 8/9/2016 at 4:13 PM, kevin gilmore said: http://gilmore.chem.northwestern.edu/kgsshvcarbonpsleft.jpg http://gilmore.chem.northwestern.edu/kgsshvcarbonpsright.jpg older power supply schematic without the on/off switch http://gilmore.chem.northwestern.edu/goldenreferencehvsic.pdf you can use that schematic and figure out the extra three parts now I see its been added, BOM is harder, write down the silk screen and look it up or wait for Kerry. Haven't seen any build this but Him Edited February 24, 2017 by congo5
Kerry Posted February 25, 2017 Report Posted February 25, 2017 (edited) Here's a rough BOM. You'll need to double check things. Patterns are not necessarily correct, but part numbers probably are pretty close. Use this as a guide... ID RefDes Pattern Name Value Vendor Part Number Quantity 100 A5 Bridge HV BRIDGE BR GBU-610 1 101 AC-IN2 Mate-N-Lok 2 Connector 2 Pin 325VAC sames series as 3 pin 1 102 DC-OUT Mate-N-Lok 3 Connector 3 Pin 571-1-770170-0, 571-1721661, 571-770988-1 1 103 AuxPwr, PWR-IND Header 1x2 Connector 2 Pin 2 104 C1 CAP_2815 47uF 80-T491D476K020 1 105 C11 Cap 22.5PS 10.5x22.5 .22uF B32913A5224M 1 106 C13 Cap 22.5PS 10.5x22.5 .33uF 505-MKS4.33/1000/10 1 10 C14, C16 Cap 15PS 9x18 0.1uF 505-MKS4.1/1000/10 2 108 C23 CAPPR-10/35h20 330uF 594-MAL215959181E3 1 9 C25 Cap 15PS 9x18 47nF I used 100pF instead 1 110 C26 Cap Pol 10PS 25D 220uF 80-ELG157M450AR4AA 1 16 C27 CAP_1206 5pF 581-12067A5R6CAT2A 1 112 C36 Cap Pol 2.5PS 6.6D 470uF 647-UVR1A471MED 1 113 C40 Cap Pol 2.5PS 6.6D 47uF 667-EEA-GA1A470H 1 25 D12, D13, D23, D25 SMA FM4007 4 27 D14 SMA 130V 1SMA130Z 1 29 D15, D16, D17 SMA 150V 1SMA150Z 2 25 D20 SMA 1N4004 FM4007 1 26 D22 SMA 24V 1 24 D24 SMA 15V 1 121 Q10 TO-220 FQPF8N80C FQPF8N80C 1 41 Q13 SOT23-5 HN4A51J 1 36 Q15, Q16 TO-220 KSC5026 KSC5026 2 44 Q21 SOT23 MMBT3904 MMBT3904 1 44 Q31 SOT23 MMBT3904 1 45 Q32 SOT23 MMBT3906 MMBT3906 1 39 Q36 SOT223-4 STN9360 STN9360 1 43 Q37 SOT89 DN2540 DN2540 1 54 R1, R41, R29, R30 RES_1206 3K 4 130 R2 RES_1206 600 667-ERJ-8ENF6040V 1 131 R3, R38, R78 RES_1206 1K 71-TNPW12061K00BEEN 3 55 R25 Res500LP 50K 1 56 R26 Res500LP 1M 1 57 R27 Res500LP 4.7M 1 136 R29, R30 RES_1206 100K 71-TNPW1206100KBEEN 2 60 R31 Res500LP 10M 1 138 R36 Res500LP 4 71-CPF33R3000FKRE6 1 139 R37, R42 RES_1206 390K 71-TNPV1206390KBEEN 2 49 R39 RES_1206 2K 1 48 R40 RES_1206 100 1 143 R43, R46 RES_2512 330K & 390K 300K 2 144 R44 RES_1206 20K 71-TNPW120620K0BEEN 1 53 R45 RES_1206 50K 1 65 R65 RES_0805 100K 1 67 R70 RES_0805 20K RG2012P-203-D-T5 1 68 R72 RES_0805 10K RG2012P-103-D-T5 1 69 R73, R75 RES_0805 2K RG2012P-202-D-T5 2 70 R74 RES_0805 3.3K RG2012P-332-D-T5 1 61 R79 RES_1206 4.7K 1 152 U1 SOIC-8/150mil D LT1021DCS8-10 1 153 U2 CPC1117N CPC1117N 1 154 U3 TO-220 10M90S IXCP10M90S 1 155 U8, U14 TO-220 IXCP10M90S 2 156 U11 SOIC-14/150mil CD4093 595-CD4093BM 1 157 VR1 POT T93B 50K 652-3266W-1-503LF 1 Here's the schematic: SingleRailGRLV400V.pdf SingleRailGRLV400V-2.pdf EDIT: I made some tweaks to the PS. I'll need to see what I did. I think I added some extra capacitance. Edited February 25, 2017 by Kerry
drmlyung Posted February 26, 2017 Report Posted February 26, 2017 Thank you Congo5, thank you Kerry. I shall start to source the board set soon. On 2/22/2017 at 3:29 PM, JoaMat said: Needs more work - a lot. Board size 4.5 in x 2.4 in. No trimmers, servos on bottom. Is this an Amplifier board with surface mount components?
