gepardcv Posted May 9, 2016 Report Posted May 9, 2016 9 minutes ago, JoaMat said: 4180G 4180G is the insulating pad, which I know about. I thought you were using a special shoulder washer..? 2 hours ago, spritzer said: My two failed units would beg to differ. I've stopped using the shoulder washers as they simply don't cut it. Do you use PEEK bolts, then? Do you hand-tighten them, or use a specific torque?
JoaMat Posted May 9, 2016 Report Posted May 9, 2016 With SiC I don't use any shoulder washer, just metal screw - torque set to 81 Ncm on the scale. 1
spritzer Posted May 9, 2016 Report Posted May 9, 2016 No shoulder washer with the SiC but be careful as the gap isn't so big. With the PEEK stuff I hand tighten as when you've done it enough times you know how far to go. 1
joehpj Posted May 10, 2016 Report Posted May 10, 2016 (edited) I use washer that has sleeve longer than tab thickness. And I enlarged the hole on the thermopad to make sure the sleeve was inserted into the pad. I suspect if the sleeve length is equal to the tab thickness, the tolerance of parts may make it prone to arch. Both washer and pad come from china, not mouser parts. Two builds (KGST, carbon) now, no problem. For forward and harsh of carbon, after burning for 4hrs/day, 2 weeks, it improved quite a bit. The sound character now is really like a puncher KGST. Mid and tremble are nearly equal. Soundstage are wider. It sounds like to have more headroom and control if turning the volume super high. But I usually listen to lower volume though. Edited May 10, 2016 by joehpj
johnwmclean Posted May 13, 2016 Report Posted May 13, 2016 (edited) Progress... I’m going to need smaller hands Edit: When testing the boards I easily attained 20mA using 120ohm resistors with zero offset and balance. Edited May 13, 2016 by johnwmclean 6
johnwmclean Posted May 13, 2016 Report Posted May 13, 2016 and takes so much longer in multiples... 6
gepardcv Posted May 13, 2016 Report Posted May 13, 2016 That looks sweet. I'm stuck on casework with mine. Drilling and tapping heatsinks for the first time. Turns out it sucks without a drill press. 1
Pars Posted May 14, 2016 Report Posted May 14, 2016 Very nice John! I really like the finish and the lettering on the top. Is that some sort of brushed finish? And whose cases are those? Modushop?
johnwmclean Posted May 14, 2016 Report Posted May 14, 2016 (edited) 13 hours ago, gepardcv said: That looks sweet. I'm stuck on casework with mine. Drilling and tapping heatsinks for the first time. Turns out it sucks without a drill press. ... and even with a drill press it’s no bed of roses. Pars the cases are my custom design and size, the heatsinks were bought eBay (from China), the panels were all fabricated by Cam-Expert, they also drilled the heatsinks, I sent them images of the style of brushed finish I wanted and they matched it. Internally the amps measure 300mm(w) 280mm(d) x 115mm(ht), its quite a fit, having lots of fun wiring atm . Edited May 14, 2016 by johnwmclean
chiguy Posted May 14, 2016 Report Posted May 14, 2016 Beautiful work! What transformers are you using?
headinclouds Posted May 14, 2016 Report Posted May 14, 2016 Good work John! A nice tidy build coming on. Have you listened to a breadboard build?
johnwmclean Posted May 14, 2016 Report Posted May 14, 2016 Geoff, I’ve not heard anything yet. Will be interesting when I do, I have a KGSSHV, BHSE and DIYT2 for comparison .
joehpj Posted May 14, 2016 Report Posted May 14, 2016 I like that bullet-shape feet. Do you have a link?
HemiSam Posted May 14, 2016 Report Posted May 14, 2016 Beautiful work, John! The case is a beaut. Love the finish and the footprint. HS
kingofsnake Posted May 14, 2016 Report Posted May 14, 2016 Lovely work nice and compact. Thanks for sharing.
headinclouds Posted May 15, 2016 Report Posted May 15, 2016 21 hours ago, johnwmclean said: Geoff, I’ve not heard anything yet. Will be interesting when I do, I have a KGSSHV, BHSE and DIYT2 for comparison . Excellent! It will be good to hear your views on it. I had a breadboard running a few months ago and sadly had to clear it off the desk after a couple of weeks. It was very nice while it lasted. I am looking forward to the proper build - my 007 Mk1 seemed to like it and since then I have also an L700.
joehpj Posted May 15, 2016 Report Posted May 15, 2016 would like to know comparison between 007 and l700
Laowei Posted May 15, 2016 Report Posted May 15, 2016 Really clean and inspiring build John! Lots of clever details. Bet it will sound fantastic!
wokstarr26 Posted May 15, 2016 Report Posted May 15, 2016 Wow John I am really impress with you design skill with casing design and build. John can I one day come to your place to hear and compare when you complete your Carborn build if l happen to be in Sydney side? As for myself I am finishing my KGST casing after a very long delay. Mange to track down a small machine shop locally to cut a rectangular hole for ventilation on my 5mm top panel and plan to fix a piece of perforated Al sheet to it. i shold get it in a moths time. Things move sloowly in the country.
wokstarr26 Posted May 15, 2016 Report Posted May 15, 2016 I am having trouble editting my previous post John time wise I am thinking next January or Feb if it is ok with you. Thanks in advance
johnwmclean Posted May 16, 2016 Report Posted May 16, 2016 On 14 May 2016 at 11:04 PM, joehpj said: I like that bullet-shape feet. Do you have a link? They're Justin's from many years ago, I think... maybe, my spare parts bin is just out of control. workstarr26, check your pm.
