judo Posted August 13, 2024 Report Posted August 13, 2024 I think my caps came from the group buy organized by @sorenb in 2015. 680u 550v from "FTcaps Germany". (These were overkill because my carbon was 400v). Maybe bad apples or any other cause, the bought volume was enough for more than 10 carbons. I think I would replace the caps in your place in the positive supply too, less fuss. Quote
mattmatt Posted September 9, 2024 Report Posted September 9, 2024 Hi guys, I've had these boards for a few years now and want to build them now, I have a full folder of the golden reference and kgsshv carbon schematics and pcb layout prints. There are a lot and confuses me. Below are the boards that I have. I hope some can point me to the right file for the PSUs and amp section. Can someone verify if this is the proper schematic for the amp? Quote
Pars Posted September 10, 2024 Report Posted September 10, 2024 That looks like the correct schematic. The boards look fine I think, assuming that the one on the right, which is chopped off in the photo, is for -400V. Given the age of these boards, you might scan completely thru the thread to ensure there were no board errors found. I seem to recall one, which did not affect the boards that I used. Here is a schematic for the GRHV. The 900 board you have listed above is for something else (Megatron or something). Also note there is a separate GRHV thread now as well. goldenreferencehvsic.PDF Quote
mattmatt Posted September 10, 2024 Report Posted September 10, 2024 4 hours ago, Pars said: That looks like the correct schematic. The boards look fine I think, assuming that the one on the right, which is chopped off in the photo, is for -400V. Given the age of these boards, you might scan completely thru the thread to ensure there were no board errors found. I seem to recall one, which did not affect the boards that I used. Here is a schematic for the GRHV. The 900 board you have listed above is for something else (Megatron or something). Also note there is a separate GRHV thread now as well. goldenreferencehvsic.PDF 24.61 kB · 6 downloads Hi Pars, Thank you for your reply. I appreciate it. I was kinda worried that the thread is old and no one checks on it. Here are the photos of the PSU boards. Just want to ask for verification, the goldenreferencehvsic is the whole schematic for the 2 boards? Doesn't seem complete to me. Do we also have an existing BOM right now? Every link that I try to open are dead as of now sadly. I'm kind of embarrassed to ask here coz I may sound like an idiot. I've read the forum quite a lot repeatedly but still seems loss at some points. Quote
MLA Posted September 10, 2024 Report Posted September 10, 2024 So, the golden rule for Kevin Gilmore boards seems to be to always follow the board. Schematics are sometimes earlier drafts rather than the finished design, which can be confusing. I have build both the 1.8 GRHVs and the .6 Carbon boards which you have with success. If you go for +/-400V rather than 450V, SimmConn has a nice post on how to push the pzta42 back into a more linear region. The BOM excels and links to Mouser carts posted by mwl168 in the first post of this thread both open and download without issues for me. Should be a good place to start. Quote
mattmatt Posted September 10, 2024 Report Posted September 10, 2024 1 hour ago, MLA said: So, the golden rule for Kevin Gilmore boards seems to be to always follow the board. Schematics are sometimes earlier drafts rather than the finished design, which can be confusing. I have build both the 1.8 GRHVs and the .6 Carbon boards which you have with success. If you go for +/-400V rather than 450V, SimmConn has a nice post on how to push the pzta42 back into a more linear region. The BOM excels and links to Mouser carts posted by mwl168 in the first post of this thread both open and download without issues for me. Should be a good place to start. Oh, you're right! I've been trying to download everything by clicking only. never thought of right click and save as. My stupid ass's mistake. Just wondering, I'm no expert with transformers and all, what does this mean? For a 400V PSU: 2× 335VAC @200mA 16-0-16VCT (anywhere from 15-0-15VCT to 18-0-18VCT should work fine) @500-700mA (the higher amperage is way overkill) Do I need 2 secondary windings for the 335VAC and 16VAC or 2 split leads will do? Quote
Pars Posted September 10, 2024 Report Posted September 10, 2024 For the 335, you'll need dual (2x335 as shown). Are you planning on using a GRLV or the onboard +/-15V supply? For a GRLV, you can use either (depending on version of the GRLV). If your board has space for 3 bridges, you can use either a center tapped transformer, or dual secondaries. It it is only 2, then you need the dual 2x15V secondaries. You are pretty much always safe with dual secondaries vs. center tapped. Quote
mattmatt Posted September 11, 2024 Report Posted September 11, 2024 6 hours ago, Pars said: For the 335, you'll need dual (2x335 as shown). Are you planning on using a GRLV or the onboard +/-15V supply? For a GRLV, you can use either (depending on version of the GRLV). If your board has space for 3 bridges, you can use either a center tapped transformer, or dual secondaries. It it is only 2, then you need the dual 2x15V secondaries. You are pretty much always safe with dual secondaries vs. center tapped. I'm not planning to use any other boards other than the ones I have currently so i'll be using the +/-15V on board. Stupid question. What's the reason to use dual secondary winding vs single winding and just splitting wires into 2? Quote
insanity Posted October 31, 2024 Report Posted October 31, 2024 (edited) I just had one of the main capacitors blow in my Carbon which is a few years old and has been lightly used. I think its the input cap of the -400v board. The Caps are from the Groupbuy a few years ago (2015 OMG). F&T Germany 550V 680uf. Toroid is 2x 117v (234V AC In) and for the HV 2x330V out. Resistors on the boards for 400v configuration. Any idea what could have caused this?? Usually caps only blow from overvoltage?? The music was still coming through flawlessly after the bang, but I turned it off right away and checked the internals. I hope the other components are ok. Maybe it would be worse if it was the output cap. I am not 100% sure if the other 3 Caps may be slightly bulged or if they came that way from the factory. I will replace all 4 for sure. Does anyone have a partnumber from mouser ready? if I remember correctly a bit less capacitance would also work, right? What is reasonable? Edit: I just read some of the previous post with a similar problem. Maybe these caps are really trash... Edit 2: Just found the datasheet from the group buy I would probably order 4 of these (only 560uf, but should be enough) and hope everything still works after replacing... https://www.mouser.ch/ProductDetail/KEMET/ALA7DA561EF550?qs=IS%2B4QmGtzzosEBZF0Z4Lbg%3D%3D Edited October 31, 2024 by insanity 1 Quote
jamesmking Posted November 1, 2024 Report Posted November 1, 2024 (edited) 13 hours ago, insanity said: Electrolytic caps are well known for being relatively fragile. Almost any reverse polarity voltage will damage them over time. They also degrade with temperature and time too. The input caps take the highest hammering because of the higher input AC voltage peaks compared to the output caps - (which only have to handle well regulated DC). Check if the diodes in the bridge rectifier are leaking, if one of the diodes starts to leak more than a couple of volts that would degrade your input cap. Also, when you have got the amp up and running again it might be worth monitoring the temperatures close to the caps, a rough rule of thumb is every 10C degrees rise in temperature halves the cap life. I have had good reliability experiences with kemet al10 series caps - although they can be expensive they are rated at around 15000 hours at 85C - significantly higher life expectancy than your caps and life expectancy. Part number ALC10A681EL550 is 550V 680uF. The ripple current of the kemet is 50% higher than your caps, but the esr of the kemets is higher, leakage current is the same. Unfortunately kemets tend to go in and out of stock again and the pricing can also be somewhat erratic. note the ALc10 kemets tend to be tall rather than wide - the ALC10A681EL550 is 80mm tall and so you would have trouble fitting it into a 2U high case. Edited November 1, 2024 by jamesmking Quote
judo Posted November 1, 2024 Report Posted November 1, 2024 Died by age not by usage I think. My carbon was rarely used. I have the same problem, same caps, all four are bad. Bad quality so who got these caps from the same group buy have to be cautious. My amp is taken apart on my workbench for months I have more serious problems, illness in the family. I hope I can continue the repair in the near future. 1 Quote
insanity Posted November 1, 2024 Report Posted November 1, 2024 (edited) 8 hours ago, jamesmking said: Electrolytic caps are well known for being relatively fragile. Almost any reverse polarity voltage will damage them over time. They also degrade with temperature and time too. The input caps take the highest hammering because of the higher input AC voltage peaks compared to the output caps - (which only have to handle well regulated DC). Check if the diodes in the bridge rectifier are leaking, if one of the diodes starts to leak more than a couple of volts that would degrade your input cap. Also, when you have got the amp up and running again it might be worth monitoring the temperatures close to the caps, a rough rule of thumb is every 10C degrees rise in temperature halves the cap life. I have had good reliability experiences with kemet al10 series caps - although they can be expensive they are rated at around 15000 hours at 85C - significantly higher life expectancy than your caps and life expectancy. Part number ALC10A681EL550 is 550V 680uF. The ripple current of the kemet is 50% higher than your caps, but the esr of the kemets is higher, leakage current is the same. Unfortunately kemets tend to go in and out of stock again and the pricing can also be somewhat erratic. note the ALc10 kemets tend to be tall rather than wide - the ALC10A681EL550 is 80mm tall and so you would have trouble fitting it into a 2U high case. Do you think this type would be fine aswell? https://www.mouser.ch/ProductDetail/KEMET/ALA7DA561EF550?qs=IS%2B4QmGtzzosEBZF0Z4Lbg%3D%3D It is in stock at mouser, whereas the other have a very long lead time. My case is 3U because the old caps were quite high aswell. But if I use some with a bit less capacity, they will be small anyway. If I remember correctly 680uf was overkill anyway. Edited November 1, 2024 by insanity Quote
Pars Posted November 1, 2024 Report Posted November 1, 2024 Those would be fine. Some drop down to the 470uf in that cap as well, particularly if you are trying to get this in a 2U chassis. When I built the one I did for a French user, the 680uf were no longer stocked at mouser in the US. Some discussion in the GRHV thread here: Quote
insanity Posted November 2, 2024 Report Posted November 2, 2024 (edited) I finally got all four caps out... This was such a big pain without a real desoldering station at hand. I had to cut all caps open to get them out without destroying at PCBs. When open all the remaining 3 had built up pressure in them. I guess it would have been a matter of time until the next one would have given up. I would therefore encourage anyone who has these caps in use to either replace them now, or keep a really close eye on them. Now gotta order the replacement ones. Edited November 2, 2024 by insanity Quote
insanity Posted November 23, 2024 Report Posted November 23, 2024 Just wanted to report that the amp is up and running again. Luckily nothing but the blown cap was damaged. Thank you for your support and help. Quote
judo Posted November 23, 2024 Report Posted November 23, 2024 Mine too. I had no no time and nerve so I replaced the big caps and all sands in the negative psu. I have to check yet which parts died. There was a few similar catastrophe so this may be interesting. Thanks the help too. Quote
Pars Posted November 23, 2024 Report Posted November 23, 2024 Good to hear on the caps insanity. Did you use the Kemets? I think those are pretty good, at least I haven't heard of anyone having problems with them though I don't know how long they have been in use and don't recall the history of that brand. I see they are owned by Yageo now. Desoldering those shouldn't have been a big deal. You just need a big enough tip and use a good solder sucker such as an Edsyn or an Engineer. I use a 3.2mm chisel tip on my Hakko 936 iron, and turn the temp up >700F for larger connections such as this. The boards these days are pretty good, particularly 2 layer boards, in terms of reworkability without lifting traces. Quote
judo Posted November 23, 2024 Report Posted November 23, 2024 (edited) That boards from the group buy nine years ago fortunately was good enough. For desoldering maybe the best tool is the Denon sc-7000z so I had no worries replacing a lot of parts as now. Edited November 23, 2024 by judo Quote
insanity Posted November 24, 2024 Report Posted November 24, 2024 10 hours ago, Pars said: Good to hear on the caps insanity. Did you use the Kemets? I think those are pretty good, at least I haven't heard of anyone having problems with them though I don't know how long they have been in use and don't recall the history of that brand. I see they are owned by Yageo now. Desoldering those shouldn't have been a big deal. You just need a big enough tip and use a good solder sucker such as an Edsyn or an Engineer. I use a 3.2mm chisel tip on my Hakko 936 iron, and turn the temp up >700F for larger connections such as this. The boards these days are pretty good, particularly 2 layer boards, in terms of reworkability without lifting traces. Yes I used the Kemets 550v 560uf since 680uf were not in stock. I think the original caps were difficult to desolder because i soldered all 4 connections and the leads were touching the walls of the holes. Quote
Michelag Posted February 8 Report Posted February 8 Hello Friends, new member here. First I'd like to thank those who made my admission possible (Todd, Nate, Kevin). So, I entered this fantastic world by purchasing my first stax, a L303, at a bargain price, now I need to build an amp 😁 Well, I'm quite experienced (seasoned) in diy audio gear, both SS and tubes, tht and smd, so now I'm slowly gathering ideas, schematics, Gerbers for last working developments of the carbon, please, hints, suggestions, everything is welcome. A newbie wouldn't be a newbie without a request on his first post 😁, so, if somebody has some spare PCB for this project, and wants to send them (I'll pay postage of course), I'll be grateful. I'm based in central Europe . So, thank you, and keep going on! Quote
sorenb Posted February 23 Report Posted February 23 On 2/8/2025 at 8:46 AM, Michelag said: Hello Friends, new member here. First I'd like to thank those who made my admission possible (Todd, Nate, Kevin). So, I entered this fantastic world by purchasing my first stax, a L303, at a bargain price, now I need to build an amp 😁 Well, I'm quite experienced (seasoned) in diy audio gear, both SS and tubes, tht and smd, so now I'm slowly gathering ideas, schematics, Gerbers for last working developments of the carbon, please, hints, suggestions, everything is welcome. A newbie wouldn't be a newbie without a request on his first post 😁, so, if somebody has some spare PCB for this project, and wants to send them (I'll pay postage of course), I'll be grateful. I'm based in central Europe . So, thank you, and keep going on! If still relevant, you can shoot me a PM; I have plenty of amp+psu boards+utility pcbs Quote
EchoRoot Posted yesterday at 12:12 PM Report Posted yesterday at 12:12 PM Hello. I'm a beginner looking to get into DIY, and I've just carefully read through this thread. I'm interested in building the KGSSHV Carbon. Unfortunately, all the zip files on the first page are gone. Is there anyone who could kindly help me? Quote
JoaMat Posted 23 hours ago Report Posted 23 hours ago Welcome to HeadCase @EchoRoot Check below two links: https://drive.google.com/drive/folders/1r3g2TAtBUaBdiMorTWX7yYgeJ7maQbYW?usp=sharing https://drive.google.com/drive/folders/152thxfZafBmisG0CKCv6X82V-Ch9TjMH?usp=sharing Quote
EchoRoot Posted 20 hours ago Report Posted 20 hours ago 2시간 전에, JoaMat이 말했다: HeadCase에 오신 것을 환영합니다@에코루트 아래 두 개의 링크를 확인하세요: https://drive.google.com/drive/folders/1r3g2TAtBUaBdiMorTWX7yYgeJ7maQbYW? usp=공유 https://drive.google.com/drive/folders/152thxfZafBmisG0CKCv6X82V-Ch9TjMH? usp=공유 Thank you, Joamat, for your warm welcome and for sharing the materials. I’ve reviewed them thoroughly and truly appreciate your support. 1 Quote
EchoRoot Posted 8 hours ago Report Posted 8 hours ago Aliexpress 1 Aliexpress 2 I had a chance to look through the Google Drive that was kindly shared. From what I’ve gathered, the KGSSHV Carbon requires three PCB components: the amplifier board, the high-voltage power supply, and the low-voltage power supply. I was able to find the v5 version of the amplifier board. The power supply boards weren’t labeled directly, but seem to be referred to as “Golden Reference.” I’d really appreciate it if someone could help me clarify a few things: – Would it be acceptable to use the ZEROZONE PCB from AliExpress? (Link is at the top) – Is the HV Dual PCB available commercially, or does it need to be custom-made? – I’ve heard that off-the-shelf transformers can’t be used and must be custom-wound. Is that correct? – If anyone happens to have spare PCBs, would you be willing to share or sell them? I’d be happy to pay via eBay and can use a shipping agent that covers both the US and Europe. I’m learning so much from this thread—thank you all for your generosity and support. Quote
