JoaMat Posted January 29, 2020 Report Posted January 29, 2020 (edited) Try MKS2-.47/63/5T, almost same thing? different price. Edited January 29, 2020 by JoaMat
jamesmking Posted January 29, 2020 Report Posted January 29, 2020 (edited) Pars for the golden ref HV on both my blue hawaii builds and my current mini T2 build I used the gerbers from the file kgsshvpssicfetdual2new This board does not have the cpc117n for the delayed start - but you can implement it via external relays. I made my own bom for it. Note you will need to change a couple of resistors if you dont want +-400V also if you are going golden reference dual LV you dont need the parts for the simple +-15V, the voltage regs, this are marked on the bom as for low voltage section. Hope this helps. On the silkscreen the caps are 0.047uF 1KV not 0.47uF, So you might be looking at a different board from the golden ref HV I used. Select Mouser No: 941-C2M1000170D Mfr. No: C2M1000170D Manufacturer: Cree, Inc. Desc.: MOSFET SIC MOSFET 1700V RDS ON 1 Ohm RoHS RoHS Compliant Availability 2 Dispatches Now £4.07 £8.14 Select Mouser No: 747-IXCP10M90S Mfr. No: IXCP10M90S Manufacturer: IXYS Desc.: Current & Power Monitors & Regulators 900V 1-100mA RoHS RoHS Compliant Availability 5 Dispatches Now £2.60 £13.00 Select Mouser No: 511-STN9360 Mfr. No: STN9360 Manufacturer: STMicroelectronics Desc.: Bipolar Transistors - BJT Hi Vltg fast-switch PNP pwr transistor RoHS RoHS Compliant Packaging Choice:Cut Tape Availability 2 Dispatches Now £0.697 £1.39 Select Mouser No: 512-2N3904TA Mfr. No: 2N3904TA Manufacturer: ON Semiconductor Desc.: Bipolar Transistors - BJT NPN Transistor General Purpose RoHS RoHS Compliant Availability 2 Dispatches Now £0.163 £0.33 Select Mouser No: 512-BC557BTA Mfr. No: BC557BTA Manufacturer: ON Semiconductor Desc.: Bipolar Transistors - BJT TO-92 PNP GP AMP RoHS RoHS Compliant - - Add new 4 Availability 4 Dispatches Now £0.178 £0.71 Select Mouser No: 512-KSC5026MOS Mfr. No: KSC5026MOS Manufacturer: ON Semiconductor Desc.: Bipolar Transistors - BJT NPN Si Transistor RoHS RoHS Compliant Availability 4 Dispatches Now £0.557 £2.23 Select Mouser No: 689-DN2540N5-G Mfr. No: DN2540N5-G Manufacturer: Microchip Desc.: MOSFET 400V 25Ohm RoHS RoHS Compliant Availability 2 Dispatches Now £1.01 £2.02 Select Mouser No: 584-LT1021DCN8-10PBF Mfr. No: LT1021DCN8-10#PBF Manufacturer: Analog Devices Inc. Desc.: Voltage References Prec 10V Ref 20ppm/-uC RoHS RoHS Compliant Availability 2 Dispatches Now £4.97 £9.94 Select Mouser No: 513-NJM7815FA Mfr. No: NJM7815FA Manufacturer: NJR Desc.: Linear Voltage Regulators 15V 1.5A 3 Terminal RoHS RoHS Compliant - - Add new for low voltage secti Availability 1 Dispatches Now £0.458 £0.46 Select Mouser No: 513-NJM7915FA Mfr. No: NJM7915FA Manufacturer: NJR Desc.: Linear Voltage Regulators -15V 1.5A 3 Terminal RoHS RoHS Compliant Lifecycle: End of Life: Scheduled for obsolescence and will be discontinued by the manufacturer. - - Add new for low voltage secti Availability 1 Dispatches Now £0.963 £0.96 Select Mouser No: 660-MF1/2CC1000F Mfr. No: MF1/2CC1000F Manufacturer: KOA Speer Desc.: Metal Film Resistors - Through Hole 100ohms 1% 50PPM RoHS RoHS Compliant Availability 2 Dispatches Now £0.147 £0.29 Select Mouser No: 660-MF1/2CC1001F Mfr. No: MF1/2CC1001F Manufacturer: KOA Speer Desc.: Metal Film Resistors - Through Hole 1K 1% 50PPM RoHS RoHS Compliant Availability 6 Dispatches Now £0.164 £0.98 Select Mouser No: 660-MF1/2CC1003F Mfr. No: MF1/2CC1003F Manufacturer: KOA Speer Desc.: Metal Film Resistors - Through Hole 100K 1% 50PPM RoHS RoHS Compliant - - Add new for headphones bias Availability 2 Dispatches Now £0.26 £0.52 Select Mouser No: 660-MF1/2CC1502F Mfr. No: MF1/2CC1502F Manufacturer: KOA Speer Desc.: Metal Film Resistors - Through Hole 15K 1% 50PPM RoHS RoHS Compliant - - Add new for headphones bias Availability 1 Dispatches Now £0.164 £0.16 Select Mouser No: 660-MF1/2CC2001F Mfr. No: MF1/2CC2001F Manufacturer: KOA Speer Desc.: Metal Film Resistors - Through Hole 2K 1% 50PPM RoHS RoHS Compliant Availability 2 Dispatches Now £0.147 £0.29 Select Mouser No: 660-MF1/2CC2002F Mfr. No: MF1/2CC2002F Manufacturer: KOA Speer Desc.: Metal Film Resistors - Through Hole 20Kohms 1% 50PPM RoHS RoHS Compliant Availability 2 Dispatches Now £0.164 £0.33 Select Mouser No: 71-RN60D-F-390K Mfr. No: RN60D3903FB14 Manufacturer: Vishay Desc.: Metal Film Resistors - Through Hole 1/4watt 390Kohms 1% 100ppm RoHS No Availability 0 Dispatches Now 4 Backordered £0.364 £1.46 Select Mouser No: 660-MF1/2CC2493F Mfr. No: MF1/2CC2493F Manufacturer: KOA Speer Desc.: Metal Film Resistors - Through Hole 249Kohms 1% 50PPM RoHS RoHS Compliant Availability 8 Dispatches Now £0.164 £1.31 Select Mouser No: 660-MF1/2CC4701F Mfr. No: MF1/2CC4701F Manufacturer: KOA Speer Desc.: Metal Film Resistors - Through Hole 4.7K 1% 50PPM RoHS RoHS Compliant Availability 2 Dispatches Now £0.164 £0.33 Select Mouser No: 660-MF1/2CC4992F Mfr. No: MF1/2CC4992F Manufacturer: KOA Speer Desc.: Metal Film Resistors - Through Hole 49.9Kohms 1% 50PPM RoHS RoHS Compliant Availability 2 Dispatches Now £0.164 £0.33 Select Mouser No: 660-MF1/2CC49R9F Mfr. No: MF1/2CC49R9F Manufacturer: KOA Speer Desc.: Metal Film Resistors - Through Hole 49.9ohms 1% 50PPM RoHS RoHS Compliant - - Add new 20 Availability 2 Dispatches Now £0.303 £0.61 Select Mouser No: 660-MOSX3CT521R5R1J Mfr. No: MOSX3CT521R5R1J Manufacturer: KOA Speer Desc.: Metal Oxide Resistors RSS3 5.1 5%TR RoHS RoHS Compliant - - Add new 2 Availability 3 Dispatches Now £0.181 £0.54 Select Mouser No: 660-MS1/2DCT52R3011 Mfr. No: MFS1/2DCT52R3011F Manufacturer: KOA Speer Desc.: Metal Film Resistors - Through Hole 1/2W3.01K ohm 1% RoHS RoHS Compliant - - Add new 1 for for headphones Availability 3 Dispatches Now £0.087 £0.26 Select Mouser No: 71-RN60D-F-806K Mfr. No: RN60D8063FB14 Manufacturer: Vishay Desc.: Metal Film Resistors - Through Hole 1/4watt 806Kohms 1% 100ppm RoHS No - - Add new for headphones bias Availability 1 Dispatches Now £0.201 £0.20 Select Mouser No: 594-VR37000004704FR5 Mfr. No: VR37000004704FR500 Manufacturer: Vishay Desc.: Metal Film Resistors - Through Hole 1/2watt 4.7Mohms 1% RoHS RoHS Compliant By Exemption - - Add new for headphones bias Availability 1 Dispatches Now £0.457 £0.46 Select Mouser No: 505-M100.047/1000/5 Mfr. No: MKP10-.047/1000/5 Manufacturer: WIMA Desc.: Film Capacitors 1000V .047uF 5% PCM15 RoHS RoHS Compliant - - Add new 2 Availability 2 Dispatches Now £0.64 £1.28 Select Mouser No: 505-MKS4.1/1000/10 Mfr. No: MKS4O131004J00KSSD Manufacturer: WIMA Desc.: Film Capacitors 1KV 0.1uF 10% PCM15 RoHS RoHS Compliant - - Add new for headphones bias Availability 4 Dispatches Now £0.718 £2.87 Select Mouser No: 581-TAP476K035CCS Mfr. No: TAP476K035CCS Manufacturer: AVX Desc.: Tantalum Capacitors - Solid Leaded 35V 47uF 10% ESR=800 mOhm RoHS RoHS Compliant Availability 2 Dispatches Now £3.77 £7.54 Select Mouser No: 75-561R10TCCV50 Mfr. No: 561R10TCCV50 Manufacturer: Vishay Desc.: Ceramic Disc Capacitors 1Kvolts 5pF 5% .25LS NPO RoHS RoHS Compliant By Exemption Availability 2 Dispatches Now £0.596 £1.19 Select Mouser No: 667-EEU-FR1E101 Mfr. No: EEU-FR1E101 Manufacturer: Panasonic Desc.: Aluminium Electrolytic Capacitors - Radial Leaded 25VDC 100uF 6.3x11.2mm LS2.5mm RoHS RoHS Compliant - - Add new for low voltage secti Availability 2 Dispatches Now £0.248 £0.50 Select Mouser No: 661-EKYB350E472ML40S Mfr. No: EKYB350ELL472ML40S Manufacturer: United Chemi-Con (UCC) Desc.: Aluminium Electrolytic Capacitors - Radial Leaded 35V 4700uF 20% Tol. RoHS RoHS Compliant - - Add new for low voltage secti 2 Availability 0 Dispatches Now 2 Backordered £2.05 £4.10 Select Mouser No: 80-ALC10A471EH550 Mfr. No: ALC10A471EH550 Manufacturer: KEMET Desc.: Aluminium Electrolytic Capacitors - Snap In 550V 470uF 20% 18k Hours RoHS RoHS Compliant Info: View Additional Product Info Availability 4 Dispatches Now £19.00 £76.00 Select Mouser No: 863-1N5927BRLG Mfr. No: 1N5927BRLG Manufacturer: ON Semiconductor Desc.: Zener Diodes 12V 3W RoHS RoHS Compliant Availability 0 Dispatches Now 2 Backordered £0.341 £0.68 Select Mouser No: 863-1N5934BG Mfr. No: 1N5934BG Manufacturer: ON Semiconductor Desc.: Zener Diodes 24V 3W RoHS RoHS Compliant Availability 2 Dispatches Now £0.364 £0.73 Select Mouser No: 863-1N5952BRLG Mfr. No: 1N5952BRLG Manufacturer: ON Semiconductor Desc.: Zener Diodes ZEN SUR30 REG 3W RoHS RoHS Compliant - - Add new for headphones bias Availability 1 Dispatches Now £0.395 £0.40 Select Mouser No: 625-Z4KE150A-E3/73 Mfr. No: Z4KE150A-E3/73 Manufacturer: Vishay Desc.: Zener Diodes 150 Volt 1.5W 5% RoHS RoHS Compliant By Exemption - - Add new for headphones bias Availability 3 Dispatches Now £0.402 £1.21 Select Mouser No: 863-1N4007G Mfr. No: 1N4007G Manufacturer: ON Semiconductor Desc.: Rectifiers 1000V 1A Standard RoHS RoHS Compliant - - Add new 2 for headphones bias 2 for for low voltage Availability 8 Dispatches Now £0.163 £1.30 Select Mouser No: 511-STTH512FP Mfr. No: STTH512FP Manufacturer: STMicroelectronics Desc.: Rectifiers high voltage diode RoHS RoHS Compliant Availability 8 Dispatches Now £1.27 £10.16 Select Mouser No: 575-113308 Mfr. No: 110-13-308-41-001000 Manufacturer: Mill-Max Desc.: IC & Component Sockets 8P GLD PIN GLD CONT RoHS RoHS Compliant Availability 2 Dispatches Now £0.929 £1.86 Select Mouser No: 651-5452257 Mfr. No: 5452257 Manufacturer: Phoenix Contact Desc.: Fixed Terminal Blocks BC-508X10- 2 BK RoHS RoHS Compliant Availability 3 Dispatches Now £0.805 £2.42 Select Mouser No: 651-5452258 Mfr. No: 5452258 Manufacturer: Phoenix Contact Desc.: Fixed Terminal Blocks BC-508X10- 3 BK RoHS RoHS Compliant Availability 3 Dispatches Now £1.22 £3.66 Select Mouser No: 532-581202B25G Mfr. No: 581202B02500G Manufacturer: Aavid Desc.: Heat Sinks Extruded Style Heatsink with Solderable Pins for TO-220, Flat-Back, Vertical Mounting, 12.8 n Thermal Resistance, Black Anodized, 2.67mm Hole, 50.8mm - - Add new for headphones bias for low voltage secti Availability 1 Dispatches Now £1.37 £1.37 Select Mouser No: 588-EA-T220-38E Mfr. No: EA-T220-38E Manufacturer: Ohmite Desc.: Heat Sinks HEATSINK FOR TO-220 BLK ANODIZED RoHS RoHS Compliant - - Add new for low voltage secti Availability 1 Dispatches Now £1.75 £1.75 Select Mouser No: 532-4180 Mfr. No: 4180G Manufacturer: Aavid Desc.: Thermal Interface Products Insulator, Aluminum Oxide Ceramic for TO-218, TO-247, TO-3P, 1.78mm Thickness, 23.24mm Availability 2 Dispatches Now £0.596 £1.19 Select Mouser No: 532-7721-10PPSG Mfr. No: 7721-10PPSG Manufacturer: Aavid Desc.: Heat Sinks Polyphenylene Sulfide PPS Shoulder Washers, Screw Size #4, 7.62x2.41mm Availability 7 Dispatches Now £0.31 £2.17 Select Mouser No: 532-4171G Mfr. No: 4171G Manufacturer: Aavid Desc.: Thermal Interface Products Insulator for TO-220, Aluminum Oxide Ceramic, 1.78mm Thickness, 16.51mm Availability 5 Dispatches Now £0.457 £2.29 Edited January 29, 2020 by jamesmking
jamesmking Posted January 29, 2020 Report Posted January 29, 2020 (edited) Pars, here is my reverse engineering of the kgsshvpssicfetdual2new I have added in red the extra parts for the delayed turn on but there are no pads present on the gerbers for them. As far as I can tell the dual hv boards stopped at version 1.7 just before the cpc117n was added. the individual "left" and ""right" boards went to version 1.8 - which included the cpc117n and the 600ohm resistor. Edited January 29, 2020 by jamesmking
simmconn Posted February 3, 2020 Report Posted February 3, 2020 I just finished building the KGSSHV Carbon and Golden reference PSUs, well, using the PCBs from AliExpress. The performance is superb. It registers 0.0006x% THD+N up to 583Vrms and the distortion profile is very well behaved (2nd order slightly higher than 3rd order). The noise floor is at 1.1mVrms wide-band without power-line frequency harmonics. I found that my comfortable listening level is around 10Vrms and would probably never need that kind of dynamic headroom. Is there a lower gain option or mod that can bring the noise down?
JoaMat Posted February 4, 2020 Report Posted February 4, 2020 Congratulations to your successful build of the Carbon. The world needs more good amplifiers. Do you mind post some images? 1
simmconn Posted February 5, 2020 Report Posted February 5, 2020 I built the amp on a heat sink taken from an old Denon home theater receiver, and decided to try it out before investing more time and $$ on a 'real' enclosure. It just so happens that the heat sink has the exact length for two boards mounted side-by-side, and width to mount the transistors on both the PSU and amp boards. The big electrolytic caps are mounted on the opposite side of the PSU board to double as temporary mechanical support. You can see the green Soviet military style HV transformer. I got it a number of years ago on ebay when the international shipping wasn't that crazy. It's better suited for circuit requiring 400V or 350V B+, though. 1
JoaMat Posted February 5, 2020 Report Posted February 5, 2020 Thanks for image. Indeed very creative built. No need for fancy cabinet I’d say, unless you have children or cats. Maybe an IR module with the motorized potentiometer for remote convenience. 1
simmconn Posted February 5, 2020 Report Posted February 5, 2020 Oh I'll definitely put these in a proper enclosure with volume control and input selection, etc. This is just temporary. By the way, do you have any suggestions to reduce the gain? Increasing the NFB would certainly do it. I'm more looking for a way to reduce the open loop gain I guess.
JoaMat Posted February 5, 2020 Report Posted February 5, 2020 Looking forward a glimpse of your final enclosure. I’ve no suggestions regarding reducing the gain. Maybe there are folks out there that have.
Pars Posted February 27, 2020 Report Posted February 27, 2020 Stupid question time, but what is the purpose of the stacked holes for the HV part mounting? Not the best pic, but best I could find.
mwl168 Posted February 27, 2020 Author Report Posted February 27, 2020 if you are referring to the large filtering caps, those extra holes were provisioned for builders to use various brand of caps in the position including the boutique Mundorf caps IIRC. The extra holes to the side were there to help with mechanical security of the caps (if so equipped) as some builders choose to mount the boards vertically on the heatsinks.
Pars Posted February 27, 2020 Report Posted February 27, 2020 (edited) Thanks Michael. Actually, I was referring to the pairs of holes for the 10M90s I believe on the Carbon boards themselves (top of pic, past the two resistors). Edited February 27, 2020 by Pars
simmconn Posted February 27, 2020 Report Posted February 27, 2020 Are you talking about the partially overlapped double holes for the C2M1000170D? I guess non-plated, oblong holes would work better, but somehow the layout person got sloppy and slapped on two plated holes (pads). 1
kevin gilmore Posted February 27, 2020 Report Posted February 27, 2020 if you are using a .5 inch heatsink bracket, you have to use the other hole because the part is too big.
Pars Posted February 27, 2020 Report Posted February 27, 2020 Kinda what I was guessing. Thanks Kevin!Sent from my iPhone using Tapatalk
Pars Posted March 3, 2020 Report Posted March 3, 2020 A pair of Carbon boards complete other than JFETs. I used Soren's pre-adjustment method on the CCS's. They all came up at 15mA initially; adjusted them to 17mA for a start. I still need to clean the boards more. These are the .6G boards and appear to have a ground plane (haven't looked at the gerbers), so all resistors, etc. are up off the board. If any of you Stax mafia dudes see anything amiss, please let me know. I was careful building these... Also, I got some pluggable connectors, Hirose DF5A (DF5A-5P-5DSA(35), DF5A-5S-5C) which are 500Vdc rated, and would fit just fine. They have one small nub or pin on the bottom, but it looks like you could either cut it off, or drill a small hole in the PCB for it. 7
mwl168 Posted March 3, 2020 Author Report Posted March 3, 2020 Just a caution for testing - this amp runs HOT! Unless you bias the output device way down, make sure you mount those angles on a proper heatsinks before you energize it. 17mA bias seems like a good starting point. I run mine around 20mA IIRC.
Pars Posted March 3, 2020 Report Posted March 3, 2020 Thanks Michael. Yes, I was going to get some heatsinks something like you used to bolt the angles to (as well as the PSU angles). And thanks for the tip awhile back about putting standoffs upside down for mounting the resistors, etc. to get them spaced off the board. Worked pretty well! They aren't perfect, but pretty good I think.
jose Posted March 3, 2020 Report Posted March 3, 2020 Mine also runs with 20mA and I am very happy with the result ... but it is a stove, be careful.
spritzer Posted March 3, 2020 Report Posted March 3, 2020 The undersized 175K resistors aren't a great idea so I'd have 1/2W units there.
Pars Posted March 3, 2020 Report Posted March 3, 2020 Those were what was on the BOM. I’ll get some 1/2W, though I think people have built from this BOM before? Is a 350V rated part sufficient?Thanks! Sent from my iPhone using Tapatalk
gepardcv Posted March 4, 2020 Report Posted March 4, 2020 Vishay RN60D are the gold standard. I used them throughout. Possibly overkill. 🤷♂️
mwl168 Posted March 4, 2020 Author Report Posted March 4, 2020 (edited) On 3/3/2020 at 10:13 AM, Pars said: Those were what was on the BOM. I’ll get some 1/2W, though I think people have built from this BOM before? Is a 350V rated part sufficient? Thanks! Chris: You need 1/2W for this position. There is significant voltage drop across these 2 175K resistors. You may have used an older version of the BOM. Check the first post on this thread where I had updated the BOM to use Vishay RN60 parts to replace the Xicon’s. Edited March 4, 2020 by mwl168
Pars Posted March 4, 2020 Report Posted March 4, 2020 I used KOA Speer 1/2W on everything I could. The 121R are Vishay/BC MRS25 (0.6W, 350V). I’ll either get some RN60 or Xicon 1/2W for the 174K.Sent from my iPhone using Tapatalk
cloudhead Posted April 16, 2020 Report Posted April 16, 2020 For those who might need LTSpice model for Cabon e.g. for debugging. Red LED is just some generic. Rename to .zip kgsshv_carbon_spice.doc
