The SRA-10S and SRA-12S are identical so this applies:
If it indeed a SRA-10S then it is 100V only (that is the reason for the model distinction) so don't run it off 117V like that.
  On 9/4/2015 at 6:37 PM, complin said:
Thanks, this will help a lot !
I'll have to wait until the unit arrives next week, but if it is a 100vac unit made for Japan only, there may be a power transformer issue.
So 10S indicates 100vac primary and 12S is for 120vac ?
Any chance of a transformer replacement to make this unit USA 120 vac compatible ?
That schematic is actually not the correct one for the SRA-10S, it is actually a modified schematic for the 10S output board (10S never used 2SC1101 output transistors, it and its big brother the 12S always used Toshiba 2SC1167).
Spritzer is right, the 12S and 10S share the same identical schematic minus a few quirks here and there with part values.
