I have a Quattro I and II with different issues, appreciate anybody who has repaired CDP's. I haven't opened these up yet, doing some research first.
  • Quattro I. Has tracking issue. Has trouble tracking some disks randomly (some 20% of the time)
  • Quattro II. Sticking/opening drawer issue. Possible to replace the drawer mechanism? Any replacement drawer pointers?
Thanks much -
No experience with Stax Quattro.
Last time I had some major sticking/opening drawer issue with Wadia transport it turned out to be aging rubber belts in the drawer mechanism needed to be replaced. Given the age of these players that's where I would look first (if belt(s) is used).
For ransom tracking issues I usually make sure there was no dust or other contamination on the laser lens first. I did have to replace a laser assembly once due to aging as well.
I wouldn't touch the pots for optical laser power and tracking as a last resort if you can't fix it via anything else.
A draw sticking problem could be a problem with the limiter/latch switch underneath the draw or an over-greased or under-greased gear/belt that is causing slippage when the draw motor kicks in to open the draw. This problem can also cause tracking issues (random skipping on a track of a cd) if the draw is not closed or opened properly, a miss-alignment in the laser head to read from the tracking of the disc.
Good tip, just so I know what I'm getting into if I have to resort to that, why should doing it be avoided?
Thanks.
Because it will permanently damage the laser. Rather a partial working laser with a fault lying elsewhere than a completely dead non replaceable laser.
Sent from my LG-D855 using Tapatalk
