I have seen bigger caps than the 470uf caps mounted horizontally, so I'm sure its ok.
a singles version of the 900v supply would be 5.95 x 4.5 inches
http://gilmore.chem.northwestern.edu/circlotronhvpowersingle.jpg
so each side of the heatsink with everything mounted vertically from the front would be
driver board
output board
900v power supply
900v power supply
hv power supply
so minimum height of the heatsink needs to be 5.95 inches
and the boards stick out a maximum of 4.5 inches
definitely fits in the 5U box ??
transformers on the back panel??
2 inch spacing between the driver and output board
then 3 inch spacing on the power supply boards (or whatever the cap height is)
Edited by kevin gilmore
How about mounting the driver/output boards vertically & the PSU boards horizontally? Should put less stress on the caps & leave enough space for toroids on the bottom plate (this is assuming 500mm depth). I can include a rudimentary sketch if needed.
Good to see this one moving forward........
RE: Cases and enclosures? Who needs em, have em built Don Garber style, open frame and easy to touch.  >:D
Edited by DefQon
its really no different than the kgsshv, its the same +/-450v output swing.
and the 900v supplies are the same as the original supply, they just float.
no big deal, nothing to see here, move along.
made the single power supply a bit smaller.
5.95 x 4.35 inches
by the way, the pdf of the kemet capacitors specifically says they
can be mounted in any position.
"350V/us", does that mean you plan to bump the current in the output stage to 42mA (assuming 120pF load)?
Would it be safe to use the original PSU board for the floating supplies if one lowers the voltage from 900V to 700V  then the original 450V caps can be used I assume
kevin gilmore said:
"this is the new power supply schematic. i like it much better than the previous version."
And I assume if you ground the input side and the output side at the junction of the two 470 uf caps you can use this PS for the KGST, KGSS, KGSSHV Carbon, BH, etc - with appropriate adjustment for the output voltage?  BTW, shouldn't R8 be 890k nominal?  Will need to find a 1 kV rated resistor for that one, or else three 350v resistors in series.
