sorenb Posted July 6, 2015 Report Posted July 6, 2015 @b0bb: should be working again, thnx for letting me know ... I make a copy of it everyday just in case
b0bb Posted July 6, 2015 Report Posted July 6, 2015 @b0bb: should be working again, thnx for letting me know ... I make a copy of it everyday just in case Working again. Thanks. I checked and updated my list Below is the updated list. V3 Amp pcb 4 boards DUAL PSU pcb 4 boards Dual LV PS pcb 4 boards
MLA Posted July 6, 2015 Report Posted July 6, 2015 Checked and updated my list entries. Definitely a YES in the yes column.
mwl168 Posted July 6, 2015 Author Report Posted July 6, 2015 for the 550v caps there is conflicting information whether they are 2 lead or 4 lead, trying to find out real information, I think they are actually 4 lead. updating all layouts with both the 2 and 4 lead versions The data sheet off mouser for the kemets I have selected say it's 2 lead (since A is the termination code right after ALC10). The ones I bought were 2 lead but they are only 180uf This is the Kemet ALC cap I used for my KGSSHV PS, 450V/680uf. They are 8cm tall. two pin snap in. http://www.mouser.com/Search/ProductDetail.aspx?R=ALC10A681DL450virtualkey64620000virtualkey80-ALC10A681DL450 Cannot speak to the 550V caps though.
kevin gilmore Posted July 6, 2015 Report Posted July 6, 2015 got something back from kemet that says their pdf is way out of date, and many of the sizes are 2 pin, but some are 4 pin. seems that mouser does not have the 4 pin in stock, but can order them, they would be a bit cheaper if we buy 100 or more. the layouts are updated just in case anyway.
Pars Posted July 6, 2015 Report Posted July 6, 2015 the following files have been updated with both footprints, please check for errors ...newleftfat ...newrightfat ...circlotronhvsingle there seem to be multiple errors in the kemet pdf for example size codes f and k do not exist http://gilmore.chem.northwestern.edu/circlotronhvpowersingle.jpg if you are planning on making any of the power supply boards make sure they have today's date or later on them. if not ask. Seems pretty clear on my read of it Kevin. Styles A and D (ALC10Axxxxxx) are 2-pin. Termination G (of the 2 std. terminations) is 5-pin, but is only used for diameters greater than 45mm. From what I could see Mouser only carries the A termination type.KEM_A4020_ALC10-535355.pdf
nopants Posted July 6, 2015 Report Posted July 6, 2015 speaking of psu components, fuck the stmicro insulated 7915. getting a solid -23v off that shit driven by 18vac 1
luvdunhill Posted July 6, 2015 Report Posted July 6, 2015 speaking of psu components, fuck the stmicro insulated 7915. getting a solid -23v off that shit driven by 18vac It just needs more current to start working, if I recall.
insanity Posted July 6, 2015 Report Posted July 6, 2015 It just needs more current to start working, if I recall. Yes I was just going to ask if you put it under load.
nopants Posted July 6, 2015 Report Posted July 6, 2015 is that specifically for stmicro? all the other devices I used have measured around 15 including other units of that same st part. what you guys are saying makes sense though if some manufacturers place an internal load or something
insanity Posted July 6, 2015 Report Posted July 6, 2015 (edited) I found an older post in the kgsshv thread stating the stm negative 15v regulator needs to be put under load to work properly. Furthermore I think Birgir has been using these isolated version for some time now and has not reported a problem. Edited July 6, 2015 by insanity
Pars Posted July 6, 2015 Report Posted July 6, 2015 (edited) Used to be National, but they are owned by TI now (probably still fine). Philips (On Semi) are good as well. Never tried JRC. Anything buy ST Micro. Thing should regulate regardless of load. Their positive ones do Ooops, On Semi was Motorola, not Philips. Philips is NXP, which probably are also good. Edited July 6, 2015 by Pars
gepardcv Posted July 6, 2015 Report Posted July 6, 2015 What non-STM 7815/7915 parts with insulated tabs are there? I'm having trouble finding anything on Mouser. Doing searches for linear regulators, +/-15V, TO220F packages. If there isn't anything, and if we think the STM parts suck, the PSU boards probably need space for heatsink insulation pads.
kevin gilmore Posted July 6, 2015 Report Posted July 6, 2015 its low voltage, so standard silicone pad is just fine. takes up about 25th, so no room necessary
s_r Posted July 6, 2015 Report Posted July 6, 2015 got something back from kemet that says their pdf is way out of date, and many of the sizes are 2 pin, but some are 4 pin. seems that mouser does not have the 4 pin in stock, but can order them, they would be a bit cheaper if we buy 100 or more. the layouts are updated just in case anyway. I'd be in for 20x 680uF/550V caps if you're going to order 100+. Right now those 20 caps take up a large sum of cash on my mouser cart. 1
Kerry Posted July 7, 2015 Report Posted July 7, 2015 ST micro regulators definitely need a load per the datasheet. It's a bit of a nuisance but otherwise work fine. Caps? Yes please.
blubliss Posted July 7, 2015 Report Posted July 7, 2015 I'm getting the "this file is going to trash" message when I go to the link on the first page of the thread??
judo Posted July 8, 2015 Report Posted July 8, 2015 I updated my list to 2x V2 amp + 2x V3 amp + 1x GR HV PS + 2x Single FAT HV PS
DefQon Posted July 9, 2015 Report Posted July 9, 2015 Ooops, On Semi was Motorola, not Philips. Philips is NXP, which probably are also good. Except for obtaining older parts, since the Motorola buyout by On Semi or merger in early 2000's, there is a shit load of fake older and commonly used On Semi and Motorola parts. 1
nopants Posted July 9, 2015 Report Posted July 9, 2015 A shame there's not even enough to hit the best listed price break, are we going to break mouser's bank
mwl168 Posted July 9, 2015 Author Report Posted July 9, 2015 The list of GB participants and number of boards seem to have stabilized. I like to finalize the counts in the next few days and request new quotes from the fab houses. Please double check and confirm or make any final updates to your record on the spreadsheet by end of day Saturday, July 11. On Sunday, July 12, I will officially close the GB, lock down the counts of the various boards, post a snap shot of the spreadsheet on this thread for your review and proceed to request final quotes from the fab houses. Once I receive the quotes, I’ll make a decision which fab house to go with and provide the cost of each individual board and calculate the total for each participant. Cost for each board will account for contribution to Kevin’s boards and cost for packaging materials (not shipping cost). Given the number of boards, I expect this to amount to around 25 cents per board. I very much appreciate Sorenb’s and all your kind offers to pay for my boards. Respectfully, I like to decline and pay for my boards. A few words about the fab houses; I requested quotes from one US fab house (PCBNET) and three overseas. PCBNET quote is, not surprisingly, quite a bit higher than two of the overseas quotes ( I have not used PCBNET in the past but they come highly recommended. My interaction with them so far has been encouraging.). The margin of difference in cost does narrow as the volume goes up. Surprisingly, one of the quotes from China is actually about 60% higher than that of the PCBNET. The cost difference will amount to a few dollars per board for the larger volume boards but can be substantial for the small volume boards. Please do feel free to share your thoughts and/or preference in this matter by responding to this posting. Please let me know if I missed something. More to come. Thanks!
