wink Posted August 5, 2015 Report Posted August 5, 2015 Payment sent. Awaiting shipping costs to Australia. Thanks for all your trouble Quote
headinclouds Posted August 5, 2015 Report Posted August 5, 2015 Paid, and details included. Thanks for doing all this Michael Quote
sorenb Posted August 6, 2015 Report Posted August 6, 2015 In rgrds to caps GB, it seems to have settled around 175 caps in total. I have negotiated that we get the same price as the +400 pieces quote.Please update the sheet with country, postal code and date for confirmation of the amount: https://docs.google.com/spreadsheets/d/1GWDWwLfsIDtwn1HB-x76lS6WyWwLd5lwsORFKiUuuEQ/edit#gid=2024111922I'll calculate estimated shipping based on location information.Thanks Quote
Pars Posted August 6, 2015 Report Posted August 6, 2015 Paid, thanks!BTW, did not include an address, but I think you have mine from the pair of multiamp boards. Quote
lkong Posted August 7, 2015 Report Posted August 7, 2015 In rgrds to caps GB, it seems to have settled around 175 caps in total. I have negotiated that we get the same price as the +400 pieces quote.Please update the sheet with country, postal code and date for confirmation of the amount: https://docs.google.com/spreadsheets/d/1GWDWwLfsIDtwn1HB-x76lS6WyWwLd5lwsORFKiUuuEQ/edit#gid=2024111922I'll calculate estimated shipping based on location information.ThanksIs the caps GB still going?I can't edit the google sheet. Quote
sorenb Posted August 7, 2015 Report Posted August 7, 2015 (edited) Is the caps GB still going?I can't edit the google sheet.The amounts has been locked ... pm if you wanna change, please I'll do a separate thread on the Caps GB in order not to make too much confusion. Edited August 7, 2015 by sorenb Quote
mwl168 Posted August 12, 2015 Author Report Posted August 12, 2015 Thanks all for your prompt responses and payments. I sent PCBnet all the latest version Gerber files yesterday for final confirmation of quotes. I will place the order soon as I receive the confirmation which I expect in a day or two.I will keep you posted. 2 Quote
congo5 Posted August 13, 2015 Report Posted August 13, 2015 I have built one of the Fat PS boards , kgsshvpssicfetsinglenewrightfatgerbers dated Tuesday, July 28, 2015, 2:38:28 PMand want to report that it works...408vdc at anything above 310vac input, bias is also good. 2 Quote
gepardcv Posted August 13, 2015 Report Posted August 13, 2015 I have found that zeners tend to run at a higher voltage than rated when warm... plus there's the 5% spec. Did you hand-pick them to be as close to the called-for voltage as possible? Do you find that the bias gets up to >600V after warming up? Quote
kevin gilmore Posted August 13, 2015 Report Posted August 13, 2015 (edited) posted for congo5power supply board known working as expected from kerry's and my prototypesfor the 400v version, input AC needs to be at least 310vacwhich would make 350vac necessary for the 450v versionso with clearance i would pick 360 vac under load for the 400v version (500v caps sufficient) and390 vac under load for the 450v version (550v or more caps sufficient) Edited August 13, 2015 by kevin gilmore 1 Quote
sorenb Posted August 13, 2015 Report Posted August 13, 2015 I have built one of the Fat PS boards , kgsshvpssicfetsinglenewrightfatgerbers dated Tuesday, July 28, 2015, 2:38:28 PMand want to report that it works...408vdc at anything above 310vac input, bias is also good.Great news, and quite a relief it is, thanks a bunch Congo5 Quote
congo5 Posted August 13, 2015 Report Posted August 13, 2015 I have found that zeners tend to run at a higher voltage than rated when warm... plus there's the 5% spec. Did you hand-pick them to be as close to the called-for voltage as possible? Do you find that the bias gets up to >600V after warming up?Not using this board for a while, if at all.. But of the 5 amps here, I have not seen any over 600v when warm.but will check again, I would think 5% would be fine. 550v-610veasy enough to change one for 20v lower or higheralso how do I know which of my 7 or so Digital Multimeters is right?Wouldn't even 10% be safe for the phones? Quote
