Looks like many people switched from v2 to v3 boards since the last time I checked the spreadsheet. Will there be a significant price difference between the v2 and v3 run based on the quotes you have seen already? I don't have a technical preference for one or the other, so should probably go for the cheaper one. If they end up costing about the same, I guess I can just stay with v2 boards.
Indeed the V2 and V3 board numbers have changed drastically in the last week or so. I won't know the cost difference until I get the new quotes based on the updated quantities.
pcbnet actually has the large board runs made in china.
only the rapid response stuff is made in Illinois
quality is very good however, the T2 boards were made by them
(my production)
That's very interesting and good to know. At the end what we really do care is the quality in relation to cost. Wonder which china fab house PCBNET uses?  :laugh:
Could someone specify the transformer requirements (current) for the carbon 400V (=standard) and 450V?? version?
2x xxxVAC ...mA
16-0-16VAC ....mA
I think I should mention that I am refering to the new GR HV PSU.
Edited by insanity
there have been updates in the boards to replace the 1 x 300k or 510k resistor
with 2 x cmf60 resistors. although there is conflicting information from Vishay
with 2 documents saying different specs for the cmf60.
I think that in any case, the 2 x cmf60 has to work because the total power is 1 watt
and the total maximum voltage is 550v
someone have a different idea, I can certainly do that.
the pdf I am going by is this
http://www.mouser.com/ds/2/427/cmfind-239942.pdf
the conflicting document is this
http://www.vishay.com/docs/31027/CMFMIL.pdf
That's what I thought as well, but I was under the impression that the industrial ratings were twice that of the mil-spec, not 4 times as this shows...
Someone has altered the spreadsheet and added the total sum of each column in the bottom, and that someone apparently did not notice that excatly the same sum is in the top ...I don't mind if people wants the sum in the bottom ...but counting in something twice isn't the best idea ....suddenly there was more than 600 boards in the GB?? if someone wants to enhance the sheet please make sure you know what you are doing  ::)
oh that was me I didn't notice the sums at the top...was just trying to see where I could be opportunistic about adding boards. my apologies
Nice thought anyways  ::)
I have added a separate sheet that links to the official, and have a consistency check, so MWL168 can see if someone is changing their values, I assume he is going to lock the GB within the next 24 hours.
is there any interest in the mundorf 4 wire capacitors?
I could change the 4 pin kemet to the 4 pin mundorf, or
add the mundorf in addition which might get a bit messy
Nice! It's great for Mundorf 4pin.
if you wire the 4 wire caps the way they want you to wire,
the board would have to change a fair bit to use those
caps, then you could only use those caps.
(board sizes would stay exactly the same)
5 more board types...
I can do that...
not sure how they would like getting I+ wired to O+ and I- wired to O-
if anyone has experience with these caps...
While I do like Mundorf's film capacitors (no experience with their electrolytic caps), my vote is to let builders have more freedom to use capacitors of their choices and not be limited to a single choice.
Edited by mwl168
Fully agree!
//UFN
My final updated list.
V3 Amp pcb
4 boards
DUAL PSU pcb
4 boards
Dual LV PS pcb
4 boards
Fat Single HV PS pcb
2 Lefthand boards
2 Righthand boards
from the GB spreadsheet it looks like people wants 30 Dual HV, 88 FAT HV PSU and 18 Skinny PSU which translate into (30+88) x 4  + 18 x 2 = 508 caps.
There´s an Estonian seller on the bay that sells those Mundorf at 29€ ....might get a better price if ordering a bunch
Edited by sorenb
The prices seem pretty close to each other so I'm fine with either option. I don't know how much it makes sense to use boutiques at the PSU compared to the local bypass spots, unless Mundorf does something special with their electrolytics
Register a new account
Sign in
