naamanf Posted May 28, 2022 Report Posted May 28, 2022 48 minutes ago, Grahame said: Lucid Air in the wild That is such a terribly color IMHO. I’ve seen a silver one here in the Little Rock which is much better. Quote
Grahame Posted May 28, 2022 Report Posted May 28, 2022 15 minutes ago, naamanf said: That is such a terribly color IMHO. I’ve seen a silver one here in the Little Rock which is much better. Money != Taste Quote
n_maher Posted May 28, 2022 Report Posted May 28, 2022 I don't mind it. Hurray for it not being black/white/grey/silver. Bring back some funky-ass colors. 1 Quote
swt61 Posted May 28, 2022 Report Posted May 28, 2022 (edited) Agreed. I'm so tired of Grey and Silver. The dream edition has a Eureka Gold that's kind of nice. I wasn't very enamored with the styling when I first saw it, but it's growing on me. Even if it does remind me of a modern Oldsmobile. I also did not like the styling of the Mercedes EQS, but after seeing one up close, it's much better in person. Both have a 0.2 drag coefficient. Crazy good. Edited May 28, 2022 by swt61 Quote
Grahame Posted May 28, 2022 Report Posted May 28, 2022 20 minutes ago, naamanf said: Grey forever. Unless it’s a Ferrari. https://www.raptorforumz.com/threads/so-what-other-colors-would-you-like-to-see-the-raptor-in.8662/ Quote
swt61 Posted May 28, 2022 Report Posted May 28, 2022 (edited) That's what happens when you let a 7 year old design a truck. Edited May 28, 2022 by swt61 1 Quote
HemiSam Posted May 28, 2022 Report Posted May 28, 2022 My “fast” car was 0.34 CoD. Awful. What I could have done with 0.20… HS 2 Quote
swt61 Posted May 29, 2022 Report Posted May 29, 2022 (edited) I remember thinking as a kid that the Countach must be really aerodynamic, only to find out later it was a brick, by today's standards anyway. 0.42 Edited May 29, 2022 by swt61 1 Quote
Grahame Posted June 8, 2022 Report Posted June 8, 2022 (edited) On 5/28/2022 at 11:19 AM, naamanf said: Grey forever. Unless it’s a Ferrari. What about Sandblast(ed)? Edited June 8, 2022 by Grahame 2 1 Quote
naamanf Posted June 8, 2022 Report Posted June 8, 2022 27 minutes ago, Grahame said: What about Sandblast(ed)? Not a fan of the color, would be nice if they did something else other than cosmetic changes. 702hp is nice but it really needs a couple hundred moar, and that’s what people were hoping for 😢 Quote
n_maher Posted June 8, 2022 Report Posted June 8, 2022 14 hours ago, naamanf said: Not a fan of the color, would be nice if they did something else other than cosmetic changes. 702hp is nice but it really needs a couple hundred moar, and that’s what people were hoping for 😢 As usual the completely sane people at Hennessey have you covered. http://hennesseyperformance.com/vehicles/dodge/ram-1500-trx/mammoth-1000/ Quote
HemiSam Posted June 8, 2022 Report Posted June 8, 2022 That’s going to be a self serve thing IMO. I don’t see Stellantis offering a lot more power on such a heavy vehicle although it’s not out of the realm of possibilities. My suggestion is an upper pulley swap supported by a “cracked” and tuned PCM and bigger injectors…poof a good bit more power. Warranty on motor and possibly trans voided, but such is the price of vroom vroom… HS 1 Quote
naamanf Posted June 8, 2022 Report Posted June 8, 2022 12 minutes ago, HemiSam said: That’s going to be a self serve thing IMO. I don’t see Stellantis offering a lot more power on such a heavy vehicle although it’s not out of the realm of possibilities. My suggestion is an upper pulley swap supported by a “cracked” and tuned PCM and bigger injectors…poof a good bit more power. Warranty on motor and possibly trans voided, but such is the price of vroom vroom… HS Satera is working on a single 80mm turbo set up that should do 900whp on E85 and 700whp on 93. Might be a good option. 1 Quote
TMoney Posted June 8, 2022 Report Posted June 8, 2022 Just be sure and wear a helmet when you go out jumping dunes and doing desert blasts. It looked like Mr. Block-enspiel was a half-second away from rolling that thing more than a few times in that video. 1 Quote
HemiSam Posted June 8, 2022 Report Posted June 8, 2022 Turbos are amazing. Very efficient but a level of complexity a good bit above a blower. Is he compound boosting or is the blower coming out? HS Quote
n_maher Posted June 8, 2022 Report Posted June 8, 2022 52 minutes ago, TMoney said: It looked like Mr. Block-enspiel was a half-second away from rolling that thing more than a few times in that video. Seriously. There were at least three that I saw: dunes, donuts, and the high-speed run. Was sort of shocked that they weren't in helmets or any gear given how hard they were pushing it. 1 Quote
naamanf Posted June 8, 2022 Report Posted June 8, 2022 4 minutes ago, HemiSam said: Turbos are amazing. Very efficient but a level of complexity a good bit above a blower. Is he compound boosting or is the blower coming out? HS Planning on options for both, with the compound being offered initially. Rippa currently has a twin turbo option that puts down about 1000whp. but they are mounted really low. 1 Quote
HemiSam Posted June 8, 2022 Report Posted June 8, 2022 Compound boost isn't my jam, but it can be made to work. Otherwise a manifold will need to replace the blower which to me is the correct way. A lot of power can be made with a single large snail or twins. I used to run twin 6766's sitting low and there are a few challenges to doing so. Access for maintenance and oil management to the turbos are the two biggest issues. I prefer the idea of one large snail sitting higher. Plumbing won't be simple with that engine bay being what it is. Swapping spark plugs now is nuts as it stands stock. I'm avoiding going down the rabbit hole with mine. It make pretty good power and is very driveable (it's my daily). I'm hoping I keep it that way. The add'l wheel HP and torque really have made it so much more fun and the AWD just makes it an urban assault vehicle and faster than it should be at the track. If going the blower route I'm a big believer in beefed up cooling and the Aussie Interchiller setup is surprisingly effective particularly if you're hot lapping it at the track. Much less of an issue with turbo's IMO. HS 1 Quote
TMoney Posted June 8, 2022 Report Posted June 8, 2022 (edited) Still can't believe you drive a 10 second jeep around, HS! I was just watching a Matt Farah vid while I was eating lunch where the 911 Turbo S only gets 9.9 with the lightweight package. 911 Turbo S speed, in a jeep! Edited June 8, 2022 by TMoney 1 Quote
HemiSam Posted June 8, 2022 Report Posted June 8, 2022 I'm adding a few images of the TT kit on my old car. It went through a lot of iterations power adder wise, but this was by far the most efficient and powerful. It was a PITA to change oil... The turbo kit was literally my K-member...the plumbing took place of the stock one. In the square piping facing the reader you'll see two hose ends...that's the oiling box. Really slick kit. You can see how much is going on. Even the frame had to be notched on the passenger side to clear the turbo which wasn't small but it was huge either. Compromises... HS 4 Quote
n_maher Posted June 8, 2022 Report Posted June 8, 2022 ^^^ You, my friend, are bananas. And it is awesome. Naaman, you are also bananas for buying a 700+HP truck and thinking it needs more. If I had access to that much HP I think I'd be featured in a different thread here. Also, who knew that the forum software had embedable stock GIFs? Huh. Learned something new today. 1 3 Quote
