sbelyo Posted May 4, 2015 Report Posted May 4, 2015 What's the polarity of the Turbulent Labs driver? Is the green dot + or - ?
n_maher Posted May 4, 2015 Report Posted May 4, 2015 How on earth would we know? I didn't even know turbulent labs existed. 1
lkong Posted May 5, 2015 Report Posted May 5, 2015 Ive got my drivers from them not too long ago. I believe there's a red dot on one contact, I assume that's +.
luvdunhill Posted May 5, 2015 Report Posted May 5, 2015 Use a DMM. That would be a neat trick. If you don't care about the driver, you could always use a 9v battery and see which way the cone moves
wink Posted May 5, 2015 Report Posted May 5, 2015 The green dot is just that... i.e. a green dot. Since these drivers are replacements for Grado drivers, one could assume that the polarity would be the same. Sometimes that is assuming too much, but if you wire both drivers the same way, who's gonna know?
sbelyo Posted May 6, 2015 Author Report Posted May 6, 2015 (edited) The green dot was the + side No dot was - These drivers are really good. I only have them running for 90 minutes with stock SR60 grills and pads and they sound pretty accurate. Now to mod some grills and try different pads. Edited May 6, 2015 by sbelyo
