This is a spin-off of another thread:
Why not just find a box at IKEA and put speaker in there? If you don't mind, I won't soil my sheets over your design, but I am sure the speaker could be voiced to sound very "audiophile".
I have long wondered why IKEA does not make flat-pack speakers.
Either a simple, but relatively large (larger than what you could conveniently load into a very small car anyways) single driver or 2-way speaker in a rectangular box (maybe with a port?) OR a crazy-super-sexxy single driver folded horn.
I wonder if the market demand for a nicer speaker is just too small :(
i know it isn't the same without the driver, but someone needs to make an open source version of this box
http://www.voxativ.com/en/loudspeakers/ampeggio-due-2/
it could be done with two hundred bucks worth of wood.  i think.
plexi version which shows the simplicity of recreating the design.
http://www.voxativ.com/en/loudspeakers/acrylic-due/
Edited by aardvark baguette
These http://www.ikea.com/gb/en/catalog/products/40104270/make awesome equipment stands.  The top is constructed the same way as Russ Andrews Torlyte - it is basically a wooden honeycomb.  Very light and non-resonant.  Price, like all Ikea is stupidly low - we're talking £8UK - so maybe 15 bucks - as compared with two orders of magnitude more for Torlyte.  So cheap in fact it is worth buying one and just trying it out.
And massively strong - I am using the double width one as a test equipment support at the moment with several hundred pounds of gear on it.
it is the Lack side table.  Looks like they do a wall mounted shelf under the same Lack series which might be interesting for a turntable support (if like me you returned to vinyl)
Go into the US Ikea site and type Lack into the search box.  The Lack side table comes up at $9.99, the coffee table at $19.99 and the wall shelf at $6.99.
The coffee table used to be supplied without the shelf, but since that is just a thin board you can leave it off, and the fixings for it too if you just want the top surface for gear.
Edited by Craig Sawyers
The older ones worked almost perfectly for mounting 19" racks on the legs too. The new ones don't have enough structure to the legs to do it tho
