Earspeakers Posted February 11, 2015 Report Posted February 11, 2015 Does anybody have a source? All I see so far is chassis mount.
dsavitsk Posted February 11, 2015 Report Posted February 11, 2015 http://www.partsconnexion.com/socket_tefcom.html
kevin gilmore Posted February 11, 2015 Report Posted February 11, 2015 if its for the kgst boards you want the machined ones also from parts connexion you just don't use the chassis strap
GeorgeP Posted February 11, 2015 Report Posted February 11, 2015 parts connexion is good but they just double the price and charge shipping on the stuff they import from China that is otherwise found on ebay.
Earspeakers Posted February 12, 2015 Author Report Posted February 12, 2015 Teflon composite - interesting. Any experience with gold versus silver plating? I used silver once for something I built years ago, which later resulted in green corrosion at the solder joint. I suspected it was because I didn't use silver bearing solder, I think I found that if you use silver plated components you have to use solder with trace silver (1% or something), which I don't have anymore. Any rate I like gold as it doesn't tarnish like silver. Thoughts? PS. Not finding any on eBay at the moment.
GeorgeP Posted February 12, 2015 Report Posted February 12, 2015 Just use your own words - 9 pin Teflon.
Earspeakers Posted February 12, 2015 Author Report Posted February 12, 2015 Just use your own words - 9 pin Teflon. teflon cmc 9 pin Yes I saw those but I believe they are chassis mount. Spot checking they all mention chassis mount only http://www.ebay.com/itm/NEXUS-MUSIC-Premium-9-PIN-9P-Gold-Plated-Teflon-Tube-Socket-12AU7-ECC83-2PCS-/181469359862?pt=LH_DefaultDomain_0&hash=item2a406aaef6 So are you saying these also will work in the KGST PC mount?
GeorgeP Posted February 12, 2015 Report Posted February 12, 2015 As Kevin said, .... you just don't use the chassis strap Yes I saw those but I believe they are chassis mount. Spot checking they all mention chassis mount only http://www.ebay.com/itm/NEXUS-MUSIC-Premium-9-PIN-9P-Gold-Plated-Teflon-Tube-Socket-12AU7-ECC83-2PCS-/181469359862?pt=LH_DefaultDomain_0&hash=item2a406aaef6 So are you saying these also will work in the KGST PC mount?
Earspeakers Posted February 12, 2015 Author Report Posted February 12, 2015 As Kevin said, I did wonder what he meant by that, Parts Connection has the PC mount I'm used to (older style with leaf flanges) which is what I thought he was talking about. Well thanks for all the help, learned something new and saved myself some money.
Craig Sawyers Posted February 17, 2015 Report Posted February 17, 2015 Teflon composite - interesting. Any experience with gold versus silver plating? I used silver once for something I built years ago, which later resulted in green corrosion at the solder joint. I suspected it was because I didn't use silver bearing solder, I think I found that if you use silver plated components you have to use solder with trace silver (1% or something), which I don't have anymore. Any rate I like gold as it doesn't tarnish like silver. Thoughts? PS. Not finding any on eBay at the moment. Bit late but could be red plague http://en.wikipedia.org/wiki/Red_plague_%28corrosion%29an electrolytic corrosion process on silver plated copper
palchiu Posted February 18, 2015 Report Posted February 18, 2015 Yes I saw those but I believe they are chassis mount. Spot checking they all mention chassis mount only http://www.ebay.com/itm/NEXUS-MUSIC-Premium-9-PIN-9P-Gold-Plated-Teflon-Tube-Socket-12AU7-ECC83-2PCS-/181469359862?pt=LH_DefaultDomain_0&hash=item2a406aaef6 So are you saying these also will work in the KGST PC mount? Yes, it's fit. May cut pin shorter let sockets lower.
