Hi Pars,
the latest revision v1.2 THD boards say BC546B and BC556B on them.
Regarding to the ZF and feedback resistor change it is for both around 2x, so 50k instead of 25k and 4.2k instead or 1.9k, basically what Paradoxper used. Important is that both modes match in volume - you may scope with 1kHz and match the 4.2k so that you get same volume in ZF-mode as in feedbak mode. This being said, I am still using 25k for feedback and 1.9k for ZF and only using the amp in ZF-mode.
As well as using the B-version sands from onsemi.
1 hour ago, audiostar said:
Hi Pars,
As I recall, the one built by paradoxper that I fixed for tkam had a bit of difference in volume (not measured) between ZF and SS modes. Close, but not exact. It was close enough that it wouldn't have bothered me. I'll order B on-semi sand.
This is why I use the original values from Kevin.
Hi, Guys,
I'm working on my CFA2 project.
I've got a matching MJF15030/15031 question : How nice is the matching?
I had a Peak DCA-75 to match these two BJTs, the result is horrible. The hfe values of One bjt are most from 280-290, the other are from 70 to 120. It is seem not nice enough, right?
So, how nice is the close enough matching of these two BJT?  May I need to buy more bjt to get nice matching?
For many device series types, the N and P are not going to match well. If you can get more devices at a reasonable price, that is always best. Where are you purchasing these devices from? A known supplier? I guess my point is, are they genuine devices? A lot of fakes out there (ebay, aliexpress, dalbani, etc.)
I got this DCA75 Pro from digikey. I think it can not be fake one. So, How close the two hfe values of these 15030/15031 are? Can you give me some values as a reference?
It's normal for 15030/15031. I had the same thing. Amp will work anyway and DC offset will be nulled out.
If you are uncomfortable with hfe difference, try using 2sa1930/2sc5171, much closer to each other by hfe. Seem still obtainable if you search.
  • 4 weeks later...
Would there be any problems with using BC556B parts with BC546C? Both On-Semi? I'd be buying 100 of each. Vendor doesn't have the 546B parts in stock (on-semi).
On 10/27/2021 at 4:23 AM, kevin gilmore said:
bc546/bc556 starting to get very hard to get even though onsemi says they are going to make more, so this which needs massive amounts of checking.
Please post the gerber file
Many thanks
Hi Gilmore Sir,
For this CFA  pcb version, Please instruct  how to select SS and ZF .
Are  SS and ZF  activated by shorting the labelled jumpers?
Can SS and ZF option  be activated at the same time?
Thanks again
Late to the party, but here goes. Lured a nice small case off of MLA for a cheap penny, wanted a compact CFA (SE).
Took some time for my slow mind to figure out how to best use the space in three dimensions, but I found a solution that works fine so far, if you're planning something similar. No interfering leads or unwanted nearness of critical components, and bias can be set without problem. In reality, I'm surprised it turned out quite airy and spacious, considering the limitations.
Note the Müller Rhombus transformer device ("Konzept Raute"). This romboid plate interacts wit the circular toroid shape and the electromagnetic waves are forced through the four holes in an endless loop in this electronically confined space, and thus traps all hum in an existant/nonexistant void. This amp is noise and hum free.
I'm particulary happy with the volume control, a 24-position Swiss Elma switch that's been lying in a drawer for 35 years. 15K (why not?), shunt coupled and making as little contribution to the signal as possible. I think this plays a part in the clean, revealing sound of the CFA design.
The odd resistor out is in the position I mostly listen to, a hand selected Syldavian military plutonium component (0,01%) from 1953, made in a numbered series of three of each value (I own the third one as well) and these days sold on ebay in Hong Kong for not less than $1200, if available at all (only one for sale during the last nine years).
Set the bias at first to 150mA, it sank to 135 after some time, which was to be expected. Decided too raise it (why not?) to 200mA. Put the lid on and after three hours it was stable at 175mA after a last fine-tuning. Gets warm, but not too hot.
Like all successful, completed builds it sounds wonderful , but if that lasts only time will tell. If so, I may be tempted to follow up with a CFA3.
Edited by mdr30
  • Like 8
so i have got a number of contacts, most with felista built amps, definitely with fake toshiba transistors that blow up.
Now another person with toshiba parts with the amp oscillating. Other changes were made, so who knows, and no idea if the transistors are real or fakes. being discontinued more than 10 years ago, everything on ebay has to be fake.
so word of warning to people building them and trying to use toshiba (fake) parts. no way to know if they are fake unless you use a transistor tester. biggest tell is that they test barely at 25-30 volts instead of 120
  • Thanks 1
11 hours ago, kevin gilmore said:
so split versions of the cfa3 board.
stack the boards together and put on the heatsink (minimum heatsink vertical dimension 83mm)
stack the boards together, use angle bracket mount horizontally for low profile chassis
Wow, thanks Kevin - thats pretty!
I wish I have waited for this but I already finished the regular cfa3 and casing it right now.
Add a board for input selection in the back, the protector3 and a board holding the pot and phones connectors in the front and this makes up for an awesome amp.
Could not resist, ordered boards...
Edited by audiostar
