stax mafia circuit boards see updated links on page 5
kevin gilmore
I appreciate all these designs and other not in the list, but even more I appreciate the way you make them available to the DIY community and your disposition to help with additional information, answering posts and private communications.
Thanks
  • 4 weeks later...
Just wanted to join in and say thanks as well.
I'm going through a mid-life crisis phase of my life, and as part of this, I'm starting to get serious about DIY audio :P
At this stage, I'm in the early phases of planning to construct a balanced dynahi amp (attempting to source some PCBs at this point, might have to fabricate some myself from the gerber's you've made available and checking to make sure I can get all the antiquated components) - got a long journey ahead, but this place has provided a great starting point.
  • 6 months later...
microsoft iis
i don't think so
and i'm way to lazy to do a web page
if someone knows a way, i can certainly can do it
what i can do is sort the directory by date and put it into info.txt file
which i will do later
just do "DIR >> directory.txt" or  simply put in a batch file
@echo off
dir >> directory.txt
and just run it everytime you do an update ...
Edited by sorenb
  • Like 1
  • 8 months later...
1 hour ago, kevin gilmore said:
at some point in the next couple of weeks, my server will be put behind a massive firewall. At which point the ip address will change and the dns will change. So it may appear to be down for up to a day.
dns change? how will this effect visitors?
