I appreciate all these designs and other not in the list, but even more I appreciate the way you make them available to the DIY community and your disposition to help with additional information, answering posts and private communications.
Thanks
  • 4 weeks later...
Just wanted to join in and say thanks as well.
I'm going through a mid-life crisis phase of my life, and as part of this, I'm starting to get serious about DIY audio :P
At this stage, I'm in the early phases of planning to construct a balanced dynahi amp (attempting to source some PCBs at this point, might have to fabricate some myself from the gerber's you've made available and checking to make sure I can get all the antiquated components) - got a long journey ahead, but this place has provided a great starting point.
question to Kevin Gilmore about the Blue Hawai:
1) Is it possible to adapt to the Blue Hawai schematic the DC servo of the kgsshv amp? if so, what changes have to be done?
2) can you provide the ref. of the leds used in the BH schematic?
Thank you very much.
BH343
I apologize for my english
microsoft iis
i don't think so
and i'm way to lazy to do a web page
if someone knows a way, i can certainly can do it
what i can do is sort the directory by date and put it into info.txt file
which i will do later
Edited by kevin gilmore
  • 6 months later...
microsoft iis
i don't think so
just do "DIR >> directory.txt" or  simply put in a batch file
@echo off
dir >> directory.txt
and just run it everytime you do an update ...
Edited by sorenb
  • 8 months later...
1 hour ago, kevin gilmore said:
at some point in the next couple of weeks, my server will be put behind a massive firewall. At which point the ip address will change and the dns will change. So it may appear to be down for up to a day.
dns change? how will this effect visitors?
