New Pete Millett/TTVJ amp - Apex Teton
shellylh
im sure nate remembers..i spent a lot of time in 2006 or 2007 working on something like this, but never took it to production. just didnt think anyone would be willing to pay for it being done the right way when the hot thing at the time was $300 versions from China. times have changed though!
For those who don't want to read the HF thread:
Quote:
The Teton has a highish output impedance similar to the original HA-2.  The Zout depends on what output tube you use...if I recall correctly it's around 100 ohms using a 6080, and as low as 50 ohms using a 6528.
Of course, the output impedance affects the sound, depending on what headphones you use.
I also added an "IEM" mode that trades gain for output impedance, so you can drive 16 ohm IEMs.  This is done with a simple resistive alternator, no magic.  So the gain is dropped by ~15dB, and Zout is lowered to ~10 ohms.
Although many would argue this amp is only good for higher impedance headphones (over 150 ohms), personally I find many lower-impedance phones (like Grados) sound better with a higher source impedance.  It depends on your taste.
Pete
I believe that I have a prototype PCB tucked away in a drawer somewhere for the amp section. :)  Hopefully this will drive tube prices in a direction that allows you to think about selling some of your 421A collection.
And I still think that the way to bring this type of amp to market is to do it like the TTVJ 307A and trafo couple the inputs and outputs and call it balanced.  Yes, it adds cost but the additional market created is worthwhile.  I also loved the Menace TC and if time/money permited it'd be the version that I'd build again with premium parts.  That was kind of where the thought process for Frankstein started...
i still have all of the 6AS7, 6080, 6528, 5998, and 421A tubes that i bought.  the last version i prototyped was a transformer output version, thinking that it would differentiate it from all of the cheap OTL amps with those tubes that had flooded the market - and that i would have to acquire WE 421A tubes to ship with the amp. its still in my storage unit on a piece of wood
Edited by justin
I was making a joke about the weight distribution
I think we all understood that it was a rhetorical question, even those of us who don't know you in person.
I love this place, sometimes you all have my sense of humor (or perhaps, mine is suddenly sympatico with all of yours).
I was also going to point out the comparison with the Wheatfield HA-2, which was downright disturbing to hold in one's hands (due to its leanings).
That would be a plan.  A lot of high end studio gear is single ended with transformers on each end so this makes sense.  Same reason the ECP L-2 should have an XLR output, we now the difference but 95% of HF have no clue.
I'd love to take that amp apart and show how 5K$ amps should be built.
Please, elaborate on your vast experience designing, building and distributing high-end electronics.
I meant aesthetics wise it looks kind of plain jane. No offense or anything it's got the plain jane look similar to the ALO Studio 6. I want more bling like BHSE level. I do own and like the low-end Jonokuchi so I don't have anything against Pete Millet's designs/amps.
I would agree
However; I would not call the BHSE bling as such, as it uses uses materials in a way which makes it look solid, well finished, there has been considerable thought given to to overall design and attention to detail.
The EAR HP4 is much more "Blingy" with all the polished chrome and gold plated knobs
Edited by complin
Given the cell-phone level of pictures being provided so far I think it's a little early to make sweeping generalizations about how it'll look in the flesh.  I'll grant you that it's never going to be flashy but it maintains the same general aesthetic approach of the other Apex offerings (Peak, Pinnacle, etc.) so there's good reason for it to look the way that it does.
And Kevin, I think that one of the top mounted bits is a large, first stage choke.  The power supply on this thing is going to be running pretty at pretty high currents (compared to normal tube gear) ~200mA so the first stage choke would need to be a lot larger than the little guys inside the chassis.  I'm basing this assumption partially off of the reference to a "multi-staged LC filter" that is in the product description and partially off of the # of wires coming through the bottom panel.  I also think they're running DC heaters for the 6NS7, which is a nice upgrade over previous iterations of this amp.  I'll be bugging Pete about it more, that much is for sure.
