spritzer Posted September 23, 2013 Author Report Posted September 23, 2013 I started the tear down of the amp. Here is the back of the front panel: I'm impressed, this is very, very nicely done. Here is the front panel stripped: Here is a closeup of the sockets. The drawback of these sockets is how sensitive they are to the metal pins. Here is a picture of the power switch and the paint flaking off: Here is the knob or rather the back of it. Nice paint spray effect, why this isn't powder coated I don't know. Far more durable... The sockets, front and back. Pretty nice design. Taken apart. Headamp Teflon socket for comparison ...and here is why they are almost impossible to use. When the Headamp sockets were made extreme care was taken to get the clamping force just right. The pins just need to be moved a bit to loosen the clamping force. Almost impossible to get them out of the chassis though... Bottom of the amp PCB. Let's play spot the cold solder joints... The PSU board. Quote
morphsci Posted September 23, 2013 Report Posted September 23, 2013 There was just one Hennyo built amp in circulation and it blew up... as soon as it arrived. ... That would probably produce a pretty loud click and/or hiss. Quote
spritzer Posted September 23, 2013 Author Report Posted September 23, 2013 I've heard it thanks to a Hennyo PSU. The spark between the rectifiers blinded me for a bit... Quote
eggil Posted September 23, 2013 Report Posted September 23, 2013 Are those solder jobs they way they came? Lots of rosin and board damage too. I can't believe this is a commercial product unless somebody tinkered with it. Quote
kevin gilmore Posted September 23, 2013 Report Posted September 23, 2013 that really is the way it arrived. and in a few places on the top, hennyo like balls of solder on the parts. seriously the solder job on this is miserable. also notice NO CONNECTORS. the whole mess is soldered together board to board from the top. Also notice that getting any of the power transistors off the heatsinks is virtually impossible. especially the ones on the triple of small heatsinks. This thing is virtually unrepairable if a part blows. updated schematic with more stuff. Quote
spritzer Posted September 23, 2013 Author Report Posted September 23, 2013 Don't I know it. Amp PCB sitting on the bench and I'm pulling heatsinks... Quote
n3rdling Posted September 23, 2013 Report Posted September 23, 2013 The comment that the KGSSHV has loud hisses and clicks was an utter lie. I had a good chuckle at that too. Quote
spritzer Posted September 24, 2013 Author Report Posted September 24, 2013 Yeah... dbel talking about anything Kevin has designed is going to be fair and honest. Been busy stripping the amp PCB and holy fuck this is cheap. I'm sure they had to force Imagineering to make something so thin. The mounting of the transistors is something truly special. Stay tuned for pictures... Quote
spritzer Posted September 24, 2013 Author Report Posted September 24, 2013 (edited) Time to share my joy with the amp board. To start off with, there is no way in hell this could ever be serviced... by anybody. If something fails in the amp it needs a new amp board as the CCS is utterly impossible to get to and the output devices are little better. The CCS has to be the most stupid design I've ever come across, 12 small sinks in a row, all of them with the overly long screws mounted one way so if KSA1156 nr. 11 or 12 needs to be replaced all of them have to be removed. Alternating the screws and using much smaller ones would have made it possible to service this thing. Anyway, time to crack on... This is how all of the mosfets are mounted. That red bit is similar to mica pads but plastic and flexible. Similar to mica these need thermal paste on both sides to conduct heat properly... How the transistors are mounted. Screw, shoulder washer, transistor, isolating film, heatsink, another shoulder washer, locking washer and the nut. So the screw is floating but to accomplish that they needed to do this: ...drill out the center holes in all the heatsinks. The middle one is a stock unit out of a new box from Aavid. What a colossal waste of time and to make matters worse, this just increases the output capacitance of the amp. That's not something it could afford... The main culprit are these. Data sheet can be found here, look for Coss and remember that two of these drive each side of the headphones and the capacitance of the main Stax lineup is 110pf. The SR-003 is 44pf and it sounds utterly horrid. Here is what the amp board looks like now. Need to remove a bunch of parts and start building up the new CCS. I'll also add terminals for the input, redo the whole input section as the soldering is quite bad. Perhaps I should get some JPS cable for its magical properties? Either that or the 50+ year old milspec silver wire cable Kevin gave me. Edited September 24, 2013 by spritzer Quote
Pars Posted September 24, 2013 Report Posted September 24, 2013 (edited) Hmm, did a little reading of that thread. Interesting. Damn, that is one thin board Birgir. Edited September 24, 2013 by Pars Quote
shellylh Posted September 24, 2013 Report Posted September 24, 2013 (edited) A serious question from someone who knows very little: why are there so many holes in the amp board? I don't think I have seen that before. Is it for ventilation? Edited September 24, 2013 by shellylh Quote
kevin gilmore Posted September 24, 2013 Report Posted September 24, 2013 yep. the thing gets stinkin hot. because the bias has to be turned way up to compensate for all the extra capacitance it has to drive. even so, its not enough. Quote
spritzer Posted September 24, 2013 Author Report Posted September 24, 2013 Well there is a story about those holes. When the Exstata was under development and I was still a part of that, I insisted that the board had holes around the heatsinks to suck up air from underneath. Alex dismissed this but finally gave in when he saw it was a good idea. Here this is taken to the extreme though as it's compromised the structural integrity of the board. One funny thing are the ground traces on top of the board. Almost no other traces are there so why on earth isn't there a solid ground plane? It lowers the noise and there are no drawbacks. Doesn't make any sense... Quote
eggil Posted September 25, 2013 Report Posted September 25, 2013 I wonder if Henyo has been hired by Cavalli Audio. He could do no worse Quote
spritzer Posted September 25, 2013 Author Report Posted September 25, 2013 That is certainly possible. Sent the pics to two people I know who assemble PCB's and they are appalled. Not just the soldering but also how utterly impossible any rework is. I've stripped all unnecessary parts off the amp board so I can start building it up again. Already installed are terminal blocks for the input , new power LED (hate blue led's) and safety output resistors. Next up are new BJT's for the output and 2SA1968's for the CCS. Then the amp will be ready for testing again. After that I have to turn my focus to the PSU. The bias supply is utterly fucked and not safe to use. Then I'll add loopouts to the back and rewire the input section. Quote
shellylh Posted September 25, 2013 Report Posted September 25, 2013 Heck, I am appalled by the soldering and I have only completed a cmoy and a guitar headphone amp! Quote
jgazal Posted September 25, 2013 Report Posted September 25, 2013 (edited) What is the cause of a poor soldering? a - Worker without skill experience; b - Thin PCB substrate and thin traces that cannot handle the temperature; or, c - Soldering station without temperature control? Edited September 25, 2013 by jgazal Quote
PFKMan23 Posted September 25, 2013 Report Posted September 25, 2013 What is the cause of a poor soldering? a - Worker without skill experience; b - Thin PCB substrate and thin traces that cannot handle the temperature; or, c - Soldering station without temperature control? All of the Above? That is certainly possible. Sent the pics to two people I know who assemble PCB's and they are appalled. Not just the soldering but also how utterly impossible any rework is. I've stripped all unnecessary parts off the amp board so I can start building it up again. Already installed are terminal blocks for the input , new power LED (hate blue led's) and safety output resistors. Next up are new BJT's for the output and 2SA1968's for the CCS. Then the amp will be ready for testing again. After that I have to turn my focus to the PSU. The bias supply is utterly fucked and not safe to use. Then I'll add loopouts to the back and rewire the input section. So we're talking a total rebuild, which would yield more or less a totally different amp? Quote
RudeWolf Posted September 25, 2013 Report Posted September 25, 2013 What is the cause of a poor soldering? a - Worker without skill experience; b - Thin PCB substrate and thin traces that cannot handle the temperature; or, c - Soldering station without temperature control? Rushing and not giving a flying fuck. Quote
purk Posted September 25, 2013 Report Posted September 25, 2013 Has the kGSSHV vs. LL MK1 comparison thread at the other site been locked? Quote
shellylh Posted September 25, 2013 Report Posted September 25, 2013 (edited) Nope. I'm surprised there aren't any posts since yesterday - maybe they are deleted? Edited September 25, 2013 by shellylh Quote
eggil Posted September 25, 2013 Report Posted September 25, 2013 (edited) They have not deleted mine (gilency). God, I just can't get over these pics. Maybe the poor soldering adds to the liquidity and smoothness of its sound. Edited September 25, 2013 by eggil Quote
purk Posted September 25, 2013 Report Posted September 25, 2013 (edited) I was really enjoying that thread. The markups on them got to be very substantial. Glad we have Justin. His BHSE is a work of art. Edited September 25, 2013 by purk Quote
johnwmclean Posted September 25, 2013 Report Posted September 25, 2013 I’m not really that surprised by the quality, they’d be many more culprits out there. And using Justin’s BHSE as a benchmark gets you nowhere, it’s stupidly cheap for such a high class product. Quote
spritzer Posted September 25, 2013 Author Report Posted September 25, 2013 Some progress: The entire CCS removed and replaced by a single 2SA1968. All transistors are now 2SC4686A's due to their super low capacitance and general awesomeness. The FJP2145 would also have been a good choice that is in current production. So we're talking a total rebuild, which would yield more or less a totally different amp? The circuit is completely identical. Only thing I've done is remove those bloody mosfets which should never have been there and fix the CCS. So now the output capacitance is cut down to less than 10pf and the huge bump in distortion from the old CCS is gone. Quote
