Yeah, but on an i5 with 8G it's fine, so maybe it's the installation.  Or maybe it's operator snobbery error snobbery.
If you read it more carefully, they are also trying to make it a desktop, so they're not going to skimp on the CPU.  Sounds like they're also going to install Ubuntu mobile, not standard desktop Ubuntu.
the difference between the mac and ubuntu versions is probably that the mac one was probably compiled with an actual optimized compiler, instead of GCC. We see 5x improvement in speed with several of the codes we run when switching from gcc to intel's compiler.
you can bring all the people in you want, and if you don't use a better compiler than gcc, you're still stuck wtih gcc's lousy performance.
Register a new account
Sign in
