skullguise Posted July 17, 2013 Report Share Posted July 17, 2013 Just got the PS Audio newsletter, an interesting product coming soon. Phono Pre and A-D Converter. Snippets: Ready to ship this September, the NPC has the best analog phono stage we've ever built in our 30 something years of building phono stages. 100% analog from input to output, this is like our famous GCPH phono stage on steroids. Passive RIAA, a class A all FET gain stage, this beauty is quiet and able to handle just about any cartridge you put on it (it has 6dB more gain than did the GCPH). In a few weeks we'll have all the specs up on the website. Info on digital output In addition to the analog phono stage we've also included a wonderful Analog to Digital converter that can take either the output of the phono stage, or the output of any analog source you wish, and convert it to either DSD or PCM. With this output you can plug directly into your DAC and play records without any compromise. Or, use the asynchronous USB output to feed the DSD or PCM signal to your computer so you can build a digital library. DSD encoding is available in standard or double rate and PCM audio is capable of up to 192kHz, 24 bit. We've even added a Digital lens to the final output to keep the digital audio sounding sweet and unjittered Quote Link to comment Share on other sites More sharing options...
acidbasement Posted July 18, 2013 Report Share Posted July 18, 2013 (edited) I'm confused. I get the part about it being a good phono pre, and I get the USB digital recording application, but the part where they suggest plugging the ADC directly into a DAC? Why insert an ADC and DAC into an analogue chain? Am I ignorant about something important here? Edited July 18, 2013 by acidbasement Quote Link to comment Share on other sites More sharing options...
dsavitsk Posted July 18, 2013 Report Share Posted July 18, 2013 Why insert an ADC and DAC into an analogue chain? Am I ignorant about something important here? It's a little weird. I could see converting to digital and doing the RIAA using DSP, but as is it makes no sense. Quote Link to comment Share on other sites More sharing options...
Nanoha Posted July 18, 2013 Report Share Posted July 18, 2013 (edited) Yeah that application is quite strange isn't it. I briefly went through the discussion thread (http://www.psaudio.com/vanilla/discussion/5310/nuwave-phono-converter/p1) and didn't find anything. Here is one very specific and strange hypothetical I thought of: - I have no dedicated preamp nor use an integrated in my non-vinyl system. I want start using vinyl in this setup. - Instead my DAC has an internal volume control / preamp. - My power amplifier has one set of inputs and the DAC is connected to it. - My DAC has multiple digital inputs. - I connect this Nuwave product to one of my DAC's unused digital inputs. - Now I can listen to both the original digital source as well as vinyl without changing any manual connections. Quite weird. Anyone think of any other reason for the ADC->DAC setup? (Disregarding any crazies who might claim the live conversion to digital adds something good.) I doubt anyone would buy a $2k product to use it in this way... The digitalization of vinyl is an understandable application though. Edited July 18, 2013 by Nanoha Quote Link to comment Share on other sites More sharing options...
skullguise Posted July 18, 2013 Author Report Share Posted July 18, 2013 I was thinking the same thing, then looked at my Wadia 151 PowerDAC, which is basically a DAC/Integrated (digital inputs only). Could make sense there..... Otherwise, for anything with an analog input, there are RCA and XLR analog outputs on the unit! Quote Link to comment Share on other sites More sharing options...
tom_hankins Posted November 30, 2014 Report Share Posted November 30, 2014 Want to bring this thread back up. Has anyone tried this PS audio yet? I'm thinking about buying one?? I would love to start putting my records to digital and this one box looks like the easiest thing/quality recordings I've read about. Quote Link to comment Share on other sites More sharing options...
jp11801 Posted December 22, 2014 Report Share Posted December 22, 2014 Tom do you plan on editing the vinyl as well? I play my vinyl through an ADC > RIAA>DAC and record a ton of it but it is something with a bit of a learning curve. 1 Quote Link to comment Share on other sites More sharing options...
grawk Posted December 22, 2014 Report Share Posted December 22, 2014 What do you use to do the RIAA curve? I'm currently running phono stage -> apogee ensemble Quote Link to comment Share on other sites More sharing options...
luvdunhill Posted December 22, 2014 Report Share Posted December 22, 2014 It's done in the digital domain. 1 Quote Link to comment Share on other sites More sharing options...
grawk Posted December 22, 2014 Report Share Posted December 22, 2014 right, the by what part is what I'm asking. Quote Link to comment Share on other sites More sharing options...
jp11801 Posted December 23, 2014 Report Share Posted December 23, 2014 Dan the metric halo uses software (MIO Console ) that allows for 8 analog channels with multiple effects one being EQ they have both encoding and decoding RIAA. I keep thinking of getting rid of the MH (just long term gear itch) but when I look at ll I use it for (DAC, phono pre, pre amp to my Genelec 8050's and a HP amp) I'd spend $4k-6K replicating it with the loss of some functions. I am a big proponent of digital domain RIAA conversions, not sure it is the best in a total marketplace view but it is not bettered by sub $3k pre amps I have owned or heard. Yes there are other flavors, largely tube flavorings but for pure clean/neutral sound it is tough to beat IMHO. Quote Link to comment Share on other sites More sharing options...
grawk Posted December 23, 2014 Report Share Posted December 23, 2014 I found a plugin to use with mainstage, maybe I'll give that a shot. That's the one thing I really wish I had that the MH provides. I love the apogee converters, but no way to run plugins without external software. Quote Link to comment Share on other sites More sharing options...
jp11801 Posted December 23, 2014 Report Share Posted December 23, 2014 Dan while I hate pure vinyls interface that may work as well, very expensive for what it is IMHO but you can trial it for 2 weeks I think Quote Link to comment Share on other sites More sharing options...
tom_hankins Posted January 12, 2015 Report Share Posted January 12, 2015 Thanks for all the help every one. Sorry I didn't get back sooner. Have been going through a lot of serious health issues..... and trying to move. Four times to the ER, and total of 15 days in the ICU in the last couple months have put a halt to all audio (sorry to say) lately. Will say, without Purks help would have never got house packed up and ready to go. Wont be able to make the move with my wife, for awhile I'm stuck here til the docs say I can make the move. 60 years old and having to move back in with mother..........shoot me now Quote Link to comment Share on other sites More sharing options...
Dreadhead Posted January 12, 2015 Report Share Posted January 12, 2015 Wow really sorry to hear that the health issues continue Tom. I hope you are able to make the move soon and things start and keep improving. Quote Link to comment Share on other sites More sharing options...
skullguise Posted January 12, 2015 Author Report Share Posted January 12, 2015 All the best, rest/heal well and hope things get moving soon! Quote Link to comment Share on other sites More sharing options...
Salt Peanuts Posted January 12, 2015 Report Share Posted January 12, 2015 Here's hoping for a speedy recovery, Tom! Quote Link to comment Share on other sites More sharing options...
nikongod Posted January 12, 2015 Report Share Posted January 12, 2015 Dislike. I hope you feel better soon. Quote Link to comment Share on other sites More sharing options...
blessingx Posted January 12, 2015 Report Share Posted January 12, 2015 ^ This. Hope things get better. Quote Link to comment Share on other sites More sharing options...
Voltron Posted January 12, 2015 Report Share Posted January 12, 2015 Fell better, Tom, and good luck at mom's! Quote Link to comment Share on other sites More sharing options...
Torpedo Posted January 12, 2015 Report Share Posted January 12, 2015 Best wishes, Tom, get well soon. Quote Link to comment Share on other sites More sharing options...
HeadphoneAddict Posted January 13, 2015 Report Share Posted January 13, 2015 Sorry about your health. Praying for your improved health! Quote Link to comment Share on other sites More sharing options...
raffy Posted January 13, 2015 Report Share Posted January 13, 2015 Get well soon Tom! Quote Link to comment Share on other sites More sharing options...
shellylh Posted January 13, 2015 Report Share Posted January 13, 2015 Whet everyone else said, get better soon! Quote Link to comment Share on other sites More sharing options...
jp11801 Posted January 15, 2015 Report Share Posted January 15, 2015 Tom sorry to hear about your health hope your back up to speed soon. Quote Link to comment Share on other sites More sharing options...
