Anyone have any quick tips for cleaning all the packing tape glue off the boards? With some work alcohol worked on small patches but some boards are covered, so looking for alternatives...
I received the boards, thanks Tran!
glue, I use WD-40 (or some other type of light oil).  Glue comes right off of many surface types when oil is applied.  Then clean off the oil with alcohol.  I use denatured alcohol, though most people use "rubbing" alcohol.
Had heard of oil before (and WD-40 in particular) for packing tape glue, but was worried about thoroughly cleaning the through-holes after. So no problems on that front?
Should not be a problem when you soak the entire PCB in solvent.  I use WD-40 to remove all sorts of glue-ish stuff, like stickers, residue, and decals.  It makes very short work of that stuff.  You can even use it to remove registration stickers on your license plate.  Glue residue doesn't like oil.
Here's a video I found on youtube just now.
The acetone should work too.
