From the blackhole thread (interesting amp, I musta missed that one), it appears that you went with the Ohmite heatsinks but didn't document which one...
Maybe a 588-C247-025-1AE ? You had an Aavid clip part number listed; it looks like the Ohmite sinks come with clips? :huh:
I'll post a pic when I get home to show the heatsinks I am using - they are quite big but still not up to snuff. If you are running the multiamp around the same current setting I am, I suggest you consider larger heatsink than the one you mentioned in your post :) Another problem with large heatsink for the GR LV is that they may interfere with the terminal block for the AC wires.
When I come to case the amp, I very likely will go with Kevin's suggestion and mount the transistors on the chassis.
Edited by mwl168
Here is a pic of my GoldenReference LV PS. The heatsinks in the front are what I originally put on it.
As I said, even these large heatsinks get hot - I can only put my fingers on them for a few seconds. I am using a toroid with 22v secondaries regulated to +/- 18VDC. My rough estimate for the current draw by the Susy Dynalo is 190mA per rail.
Edited by mwl168
I wired up a 25VA toroid with 18v secondaries to the GoldenReference (set up for +/- 18VDC) tonight and as can be expected the heatsink temperature dropped significantly powering the same Susy Dynalo amp. They still run warm but no longer hot to the touch.
I guess the take away lesson for me is to allow sufficient headroom choosing the transformer but not to get too overboard.
Spent a couple of hours dialing in the offset of the Susy Dynalo, finally sitting down to listen to some music. Happy to report everything appears to be in good working order. I settled on 18VDC rails  and 312 ohm for R38/R39 which, after warm-up, results in about 19mA per output device (380mV voltage drop on the 20 ohm emitter resistors). The MPSWx6 output devices run very warm but not hot to the touch.
  • 2 months later...
As I've been promising to do for months I'm finally working on some dynamic amps.  Here is something new, a Susy Dynalo with switchers...  ;D
Running at +/-18V there.
  • Like 4
Does your Keithley work on 4 wire mode? Recommended for all resistances up to 10kilOhms.
That's the most accurate method of measuring resistance as it compensates for the lead and contact resistances.
You also should clean the multimeter lead sockets and lead connections with isopropyl alcohol and then use Deoxit on the connections.
If the meter has a null function on the resistance ranges, you short the leads out and null the reading. That takes care of the lead resistance.
Then you measure the resistor.
Make sure the meter is on the right resistance range. I know that sounds silly, but it is an easy mistake to make, especially if your meter auto-ranges. Set the range manually.
For further reading:-
http://www.tek.com/sites/tek.com/files/media/media/resources/2w_4w_ohms.pdf
http://www.edn.com/design/test-and-measurement/4411117/2/Two-wire-vs--four-wire-resistance-measurements
http://www.pages.drexel.edu/~hj56/manual%20files/CircuitsBasic.pdf
Which heatsinks are those that you are using? I had been toying with using something like these:
http://www.mouser.com/ProductDetail/Ohmite/R2A-CT4-38E/?qs=%2fha2pyFadugu%2fkSjFHjoOqIUacMQSR81IknUuMHd2REdwNmhs01RGA%3d%3d
Edited by Pars
Sorry Pars, I don't have the part number handy. I just grabbed them from my parts bin.
I'll need to look up my past Mouser orders and see if I can find it. There is also the possibility they came wih kits I bought in the past.
I do remember the heatsinks were for TO220 package but happen to work in this case.
( I was not able to save edit to my last response so have to submit a separate response.)
8 hours ago, joehpj said:
I am more interested in the R-core transformer. Where did you get that? Is that good?:rolleyes:
It's from China and some are ok, others cause a lot of issues.
