haha if you guys put it that way I'm convinced, doesn't take much
I'm pipe dreaming here but it you might be able to squeeze the attenuator if you move the psu to a separate box. then you have the linear dps option a la Justin
3 hours ago, TMoney said:
Any chance of a Mjolnir Audio version of the mini at some point, @spritzer?
Isn't the market for a transportable balanced amp already covered? ;)
A Mjolnir version of this would be insta-buy...
It's something I could look into.  I'm going to build one and see how I like it.  :)
I'm slowly working on a full size version of the circuit so that takes precedence at least for a while.
  • Like 3
One week turn around... Not bad :)
Here's the board with 2oz copper.  I still need to finalize the BOM and get an order in.
  • Like 12
That's a possibility for the next round.  The ones from ebay have solder mask on the back.  We're going to be dissipating under 1W for each sink and I think it will be ok, but it is a question that will be answered shortly :)
I took a look at the ones that AMB is doing sig78xx/79xx.  I'm unclear whether he has mask on the back side.  Lots of good data on the forum regarding temperature rise for various power levels / heat sinks.
  • Like 1
Quote
Assuming "the production boards" are the same as the σ78 prototype I have....there is solder mask on the back side but the vias are exposed.
 Which could cause a short if an insulating pad were not used and the (proposed) exposed thermal pad on the PCB is grounded and extends past the outline of the TPS7A4701/TPS7A3301 regs.
I got the parts in this afternoon and had a chance to start stuffing.  Here's the back of the board.  A couple of things wrong.  The holes for the IEC inlet are a bit small.  I can drill them out since all the traces are on the bottom.  The other more important issue is I used the wrong size QFN-20 pattern for the regulators.  Luckily I have an off-board option that I'll be using on this version.  I ordered a couple of sig78/79 regulators from AMB's site.
I can test the rest of the board so I will continue stuffing.  Should be done tomorrow night.
  • Like 11
Just joined this site specifically because of this amp. This project simply looks awesome. I would really like to build the mini version with SMPS but I don't trust myself to solder surface mount components yet so I'll probably end up doing the original version that started this thread.
I have a couple questions. Is there any measurements posted for this amp? Is there a performance hit when using the Dynalo SuSy in a single ended configuration vs a basic Dynalo?
I am looking at kgdynalobal5 and kgdynalobal9. Version 9 looks like an SMD version and version 5 is a through-hole version. Was the SMD version developed because parts are scarce for the through-hole version? Do I assume that performance is nearly identical for both versions?
Register a new account
Sign in
