I had some comments back so I've made the following changes:
  • I reversed the SE and balanced outputs
  • I fixed a mistake in the schematic for the negative off-board voltage regulator
Thanks to Kevin (of course), Birgir, Marshall and Joachim for your feedback :D
Here's what might be the final...
Edited by Kerry
Error on one of the pics
  • Like 4
maybe i just got a bad batch, but i had a lot of trouble with the Alpha pots and plan to stop offering it in the GS-X mk2. A large percentage of them have a noticeable lump at a particular point when turning it. Sometimes you have to have a large knob attached first and then turn it slowly to find the spot. but around half of them ended up in the trash
SMD, SMPS... Blasphemy!
I'm actually super proud to see HC finally embracing the newer tech. How do these SMPS'es look under the scope? Does extra after-regulation help?
Edited by RudeWolf
1 hour ago, kevin gilmore said:
fine, cram the new digital attenuator in there. should be enough room.
Not going to be easy. I started thinking about it. A couple of daughter boards might do the trick. It would be nice to have a modular solution.
