Ordering my own it is. one sigma22 board bould be enough to power two boards right? I already have a sigma22 wired for 30V. can the amp board be changed to use 30V input?
Edited by mahdi8
if you mess with the bias and change the opamp to opa445
you can get it to work.
the input chip can handle 36v, should just make it with 30v rails
all the transistors are rated at 80v, so should be ok.
caps would have to be at least 50v, 25v won't work
Is there a groupbuy for the dynalobal board at the moment?
There needs to be, I've never coordinated one, and I'm probably too unknown to be up and doing one , but someone out there, shut up and take my money, please. Like, yesterday.
i could do an off board version with flying output transistors,
then on big heatsinks, as much power as the transformer can supply
 looking forward to this one ::)
With big output transistors? But why would you need it if Susy dynahi exists? What's the major difference? I guess none.
AFAIK, it has always been like this: dynalo = w/o big output TO-220 transistors, dynahi = with big output TO-220 transistors.
not exactly.
dynahi has cascade on the input transistors because that was right at the limit of the fets.
the bipolar part has 6 more volts rated, so cascade technically not necessary. Also vas
stage has double transistors for more output current. otherwise identical.
dynahi was also +/-30 and the ssdynalo was +/-20 although you could raise it a bit.
boards have cleared customs should be here by Friday, and I have the parts to build
and test them.
once they are verified working (and I have checked the layout many times) people
could go ahead with a group buy.
birgir is getting me prices on the power supply.
  • Like 1
oops , seems some misread on me
I  thought that kevin is going to draw an off board version of goldrefrence regulator
it would be nice if using case with heatsink on bothsides or just case itself
i will be testing the new amp boards when i get them
will order the power supply board soon
i'm sure i can do a completely off board version of the
power supply board
Yes, please call Goldreference stable and final, and I will order PCBs.
Interested in on board version.
I will chip in for the GoldenReference PSU board.
so 2 of the 3 simulators i use gave the same results for the power supply with the schematic shown.
But ltspice oscillates. Kerry made the following changes, until i build the real thing, will not know which
is right.
C3,C16   4.7nf
C4,C5  470pf
c9,c12,c8,c15  not used
no changes to the circuit board necessary for this i think
Sorry going to order for myself only, no experience to start GB if you meant it. Also, it's going to be rather expensive. The price of PCB house I've used to deal with is around 18-20USD per PCB of Goldenreference for the lot of 4 (180x110mm, double layer, FR-4, 1.5mm, 70um).
Register a new account
Sign in
