kevin gilmore
  • 2 months later...
  • 3 months later...
With the group buy of boards going on, I've been putting together a BOM for the Megatron.  I will post a link once it's more complete.  I have a few questions.
  • What tolerance and wattage is recommended for the resistors?
  • Are 680K Ohm or 690K Ohm resistors used?  I'm looking at the jpg of the amp board and that number is hard to read for me.  I think it's 680K after looking at Spritzer's populated board but I wanted to make sure.
  • There is one capacitor (in the corner) labeled as .1uF / 4630V.  I presume this is a .1uF / 630V cap?
  • There are two caps labeled as .47 / 50V.  Is this .47F or .47uF or something else?
Thanks!  :)
Mouser
Resistor/Qty
220R/8   71-CMF60221R00FHEK
500R/2   71-CMF60499R00FHEK
2K2/4   71-CMF602K2100FHEK
3K3/4   71-CMF603K3000FHBF
5K1/4   71-CMF605K1100FHEK
10K/6   71-CMF6010K000FHEK
100K/4   71-CMF60100K00FHEK
150K/4   71-CMF60150K00FHEK
250K/4   71-CMF60249K00FKEB70
330K/4   71-CMF60332K00BEBF
470K/4   71-CMF60470K00FHEK
680K/4   273-680K-RC
1M/4   71-CMF601M0000FHEK
1K5/8   71-CPF3-B-1.5K
21K/1
Capacitor
0.1uF/630V/9   505-MKP4-0.1/630/5
0.22uF/630V/4   505-M10.22/630/5
0.22uF/1000V/4   505-M10.22/1KV/10
220uF/100V/4   667-EEU-FC2A221
0.47uF/50V/2   80-C330C474J5R
Transistor
2SA1968/4
2SC1815/2
Zener
12V/4   78-BZX85B12-TAP
100V/3   78-BZX85B100-TAP
LED/4   859-LTL-4213
Tube
12AU7/2
12AX7/2
6CA7/8
I've done that before, will anyone check?
Mouser
Resistor/Qty
680K/4   273-680K-RC
21K/1
Capacitor
Transistor
2SA1968/4
2SC1815/2
Zener
LED/4   859-LTL-4213
Tube
12AU7/2
12AX7/2
6CA7/8
That list is what I have so far.  I have the .1uF caps separated into 4x 450V and 5x 630V but all 630V caps will work also.  Tube sockets, a pot, and terminal blocks are all that remain.
That looks ok and the tube sockets are the CMC teflon units (or the ceramic ones would probably work) and the terminal blocks are just the standard 0.2" pitch.
Here is how far mine has gone.
Almost took off my hand with that bloody drillpress so this is on hold while I make a few KGSSHV's.
Thanks for working on the BOM chiguy and palchiu... but if i'm not wrong the 5.1k resistors should be rated for 1W?
Edited by RiStaR
The front end draws very little power so that isn't a problem.  It's also easy to increase the current limiting of the KGSSHV supply.
Now people are going to do the same on the KGSS... again. Hennyo?
Now that would make Kevin truly furious...  :)  Did you ever see the inside pictures of that amp?  So he didn't want to spring for a +/-15V supply but the amp was filled with Z-foil resistors...  :palm:
Can anyone comment on the feasibility of buying NOS EL34's as substitutes? I know it's an old topic so I've been digging through the internet... all I can find is "they're interchangeable but one is a pentode, the other is a beam tetrode", European EL34's are America 6CA7. It's all shaping up to be a serious mindfuck
EL34 = 6CA7.  The former was developed by Mullard/Philips in Europe and the latter is just different enough to not fall under the former patent and thus avoiding the royalties manufacturers would have to pay.  It was made only in the US by Sylvania/GE though Sylvania would end up being Philips in the end...  Electrically they are almost identical and can be exchanged at will.
As for NOS, some are better... some are not.
