Blueman2 Posted January 16, 2019 Report Posted January 16, 2019 Work of art!!!! I want to listen to music staring at that.
JoaMat Posted January 17, 2019 Report Posted January 17, 2019 More Sort Guld. A Søren built amplifier is easily recognized. Very nice!!
wink Posted January 19, 2019 Report Posted January 19, 2019 23 hours ago, johnwmclean said: .... wow beautiful! So, when are you gonna build one....?
mwl168 Posted December 31, 2019 Report Posted December 31, 2019 It's winter time again - the prime time to bring out this space heater. I have forgotten how glorious this amp sounds and am reminded again how much tube choices affect the sound of this all-tube circuit - especially the front end tubes. 10
Blueman2 Posted January 1, 2020 Report Posted January 1, 2020 There can be no better use for electricity than running this amplifier. Very, very envious.
gepardcv Posted January 1, 2020 Report Posted January 1, 2020 @Blueman2: You know you owe it to yourself to build one!! ?
mwl168 Posted January 1, 2020 Report Posted January 1, 2020 ^ that. I think I may have a spare board laying around somewhere...?
jose Posted January 2, 2020 Report Posted January 2, 2020 On 1/1/2020 at 3:44 AM, Blueman2 said: There can be no better use for electricity than running this amplifier. Very, very envious. You need a Megatron ... and you know it.
Blueman2 Posted January 2, 2020 Report Posted January 2, 2020 (edited) On 12/31/2019 at 8:21 PM, gepardcv said: @Blueman2: You know you owe it to yourself to build one!! ? On 12/31/2019 at 9:22 PM, mwl168 said: ^ that. I think I may have a spare board laying around somewhere...? 1 hour ago, jose said: You need a Megatron ... and you know it. Now you guys are just getting nasty. ? Aren't you the same 3 guys who made me build the Carbon, and then the Blue Hawaii BJT after that? Come to think of it, more than 1 of you got me to build my original SRX-Plus too. Your taunts will no longer work on me. ? Edited January 2, 2020 by Blueman2 2
mwl168 Posted January 2, 2020 Report Posted January 2, 2020 There are some friends that are more helpful than others...
jamesmking Posted January 2, 2020 Report Posted January 2, 2020 (edited) Well my blue hawaii is working fine with golden ref lv and hv boards.... I want someone to convince me to build a mini t2 seems the next logical step for me without going into rare and expensive transistors.... if only i had the amp boards... or if someone would let me have the gerbers..... <a few momments later......> Me and my big mouth.... I tried to resist but looks like I might be building a mini T2 thanks to JoaMat.... Edited January 3, 2020 by jamesmking
Blueman2 Posted January 2, 2020 Report Posted January 2, 2020 (edited) From an earlier post, but worth repeating for @jose Edited January 2, 2020 by Blueman2 1 3
jamesmking Posted January 3, 2020 Report Posted January 3, 2020 in Jose's post there was a mini T2 in vaders hand it was just too small to see..... where as the megatron is too large to ignore...
jose Posted January 4, 2020 Report Posted January 4, 2020 Has anyone continued to investigate something about preamp tubes? I still use the E180CC instead of the 12AU7.
mwl168 Posted January 5, 2020 Report Posted January 5, 2020 I am also back using E180CC (Philips SQ) now for the gain tubes. Tried a pair of 6414 tubes following the Genalex 12AT7 (labelled A2900). I have yet to try the Telefunken ECC801S, Mullard CV4024 and 7316. So far I liked the Genalex A2900 and Siemens ECC801S best overall for the gain tubes. I also heard an improvement when I replaced the Tele 12AX7 with Brimar CV4004 for the driver tubes but the difference is not nearly as significant as changing the gain tubes. It may also be due to the fact that the Tele 12AX7 I was using are used tubes with unknown mileage. Just my 2 cents worth and should be taken with a large grain of salt - I was merely experimenting and most of the tubes used were NOS with only a few hours running.
jose Posted January 5, 2020 Report Posted January 5, 2020 I have been focusing on gain tubes. I've been alternating the E80CC, E180CC, 6189 ... and I think the E180CC (Mullard/Philips) is the one with the best balance (quality vs. gain level). I liked the E80CC a lot but the gain increase was minimal compared to 12AU7. For the driver's tubes, I've been using ECC803S and several "esoteric" 12AX7 for a while, but I opted for the modest ECC83 Svetlana "Winged C" and a pair of Mullard CV4004 with unknown mileage too. IMO the most critical here are the gain tubes so I have not wasted much time here. As for the "Jiml/Gilmore" modification to raise the current to the plate of the driver tube, I think it was a good upgrade (thanks to both of you and Mwl for sharing it). If I'm not wrong, only Michael and I did the mod?
simmconn Posted February 27, 2020 Report Posted February 27, 2020 I was wondering... why the first and second stages are designed at such low operating points. 12AU7 is at 1.2mA and 12AX7 at 0.5mA. Wouldn't higher operating points give better distortion and lower output impedance and hence better frequency response at the higher end?
hyperma Posted April 2, 2020 Report Posted April 2, 2020 On 2/28/2020 at 4:47 AM, simmconn said: I was wondering... why the first and second stages are designed at such low operating points. 12AU7 is at 1.2mA and 12AX7 at 0.5mA. Wouldn't higher operating points give better distortion and lower output impedance and hence better frequency response at the higher end? Probably because it's an electrostatic amplifier, the first stage needs provide 24db gain to drive pair 12au7s ,otherwise unable to reach amplititude.
simmconn Posted April 2, 2020 Report Posted April 2, 2020 12 hours ago, hyperma said: Probably because it's an electrostatic amplifier, the first stage needs provide 24db gain to drive pair 12au7s ,otherwise unable to reach amplititude. I'm not sure if I understand your reply. In the Megatron the first stage uses 12AU7, and the second stage uses 12AX7. What do you mean by "provide 24db gain to drive pair 12au7s"?
