Schematic:
Q2(Q7) Collector -  Q12(Q13)Base
Board:
Q3(Q8) Collector - Q12(Q13)Base
IN2 only (IN1 is OK)
Schematic:Q14,23&24 MJE15030
Board:MJE15031
Schematic:Q25&26 MJE15031
Board:MJE15030
+/-22V line (or +/- 21V?)
4.7uF/63V are not on the schematic
Q27 Collector
0.1uF is not on the schematic
Edited by Inu
updated schematic and picture, have a look.
very pathetic BOM in progress
includes some of the power supply
1000uf 35v ls=5 dia=13mm 871-B41041A7108M000 35 0.47 16.45
.1uf 100v ls=5mm 80-R82EC3100DQ70J 14 0.32 4.48
4.7uf 63v wima 505-MKS24.7/63/5 7 4.33 30.31
470pf 500v  ls 5.9mm 5982-15-500V470 4 2.28 9.12
39pf 500v ls 5.9mm 598-CD17ED390JO3 2 1.35 2.7
220pf 500v ls 5.9mm  598-CD15FD221JO3F 2 1.22 2.44
220uf 50v ls 5mm dia 10mm 647-UPW1H221MPD 4 0.58 2.32
4700uf 50v ls10mm 35 dia 598-SLP472M050C5P3 2 3.2 6.4
mjf15030  6 1.63 9.78
mjf15031  4 1.63 6.52
heatsink amp board 513102b02500g 8 1 8
mpsa56  19 0.12 2.28
mpsa06  23 0.32 7.36
lsk389  2
relay 653-g5v-2-h1-dc24 2 2.76 5.52
op27 digikey 4 6.01 24.04
Its about $137 not including the resistors and some of the
other power supply components. So definitely under $250
with transformer and everything.
Unless you go very nuts on the resistors.
Edited by kevin gilmore
Zettler 24V Relay
A2830-2C-24DS
http://www.bgmicro.com/REL1086.aspx
MPS8099 and 8599 (0.15)
http://www.bgmicro.com/TRNMPS8099.aspx
http://www.bgmicro.com/TRNMPS8599.aspx
It is hard to pairing MJEs…    :-[
MJE15030G(NPN)
Lot:AFA50
hfe = 78 78 80 83 96 97 98 104 104 105 107 109 111 114
MJE15031G(PNP)
Lot: AFB09
hfe = 228 234 238 241 242 252 253 257 260 262
Edited by Inu
what we need to do is find a massive stock of 1000uf/25v blackgate non-polarized caps.
The only place that has them in stock wants $80 each and we need 35 per board.
Soooo...for about 10x the price of the amp I could have it all Blackgated up? :blink: :blink:
Even if I wanted to go nuts with it, there is no way I could pull the trigger on that.
  • 5 months later...
I just order all the components and the PCB to make one ::)
I will use Nichicon FG series for the 1000uF/35V condensators. Great value for the money... Not so good as the Blackgate or Elna Silmic II, but much cheaper !
I Let you know if the name of Krell is as great as it should be :indra:
I know the goal here is to clone the krell but I am curious ; would it work to split R15 and put an integrator's output in the middle, dynalo style ? Requires to modify the servo and get rid of C10, C18 and C19 ...
