krell ksa5 klone
  • Replies 805
  • Views 372.6k
  • My Krell:
my guess is that the output transistors and the 2 ohm resistors are toast.
I replace the pot with fixe resistor to test, and everything run fine ;D
Put sine wave in the input and get an nice sine wave at the output !! Need just to wait to get the right pot...
Can someone PM me the gerbers?
Thanks!
Edit: I should ask, does anyone have a board?
Edited by holland
Thank you for another great project.
Is there a preferred version of the LSK389? Trendsetter. com has both the B & the C variant in stock.
Yeah, the B-job. It's better, you know that.
Hell, it will only cost you a buck more. What are you waiting for? Dew eet!
Or look at it this way - would you buy a crappy Escort when you got the dosh to throw down on a GT? I thought so.
Doesn't really matter which version you pick but it's normally good to go for the lowest noise.
If the B-job makes the KSA5 Klone go better like the GT, then I am tempted to pay the extra few bucks. But I might come back and complain if my KSA5 ends up with the (reported) reliability of the GT ;D
Excellent. Thanks.
original power supply version of the krell ksa5 power supply
also suitable with lower voltages for the singlepower squarewave
the later version coming shortly
http://gilmore.chem.northwestern.edu/ksa5psorig.jpg
http://gilmore.chem.northwestern.edu/ksa5psorig.zip
and here is the alternate version of the krell ksa5 power supply
http://gilmore.chem.northwestern.edu/ksa5psg.jpg
http://gilmore.chem.northwestern.edu/ksa5psg.zip
Only problem, finding some HV ones that are not for TV use and with horrible Cob....  :(
Edit.  And who ever thought it was a good idea to call the new ones TO-3P needs to be taken out back and shot.
Edited by spritzer
Silkscreen on the original board = I think R4 is 562 not 750.
Has someone finish and listening to his KSA-5 ?
I just finished mine, and I'm very disappointed :-
Sound very "thin" and clip very quickly.... Not exactly what I was waiting for !
Edit : I use a Beyerdynamic T1, which is not very difficult to drive...
don't know about T1, but sounds great on hd800 and lcd2.
this amp does not have as much voltage swing as you might
expect for something that runs on +/-21v.
better change the opamp to something that can handle that like opa445.
I have a OPA445 8)
The headphone output from my old CD player is far better ! I hope that with burn in time he will get better...
 My origional KSA5v with the blackgates has never shown any signs of clipping even when driving my k1000s at full volume( it drives them to a reasonable listening level at full volume ,but definetly could use more power then the krell can produce) but it is very clean sounding with no clipping at all. No way would I call the Krell thin sounding.
 I have found the T1 to sound best with tube amps,I have never tried the T1 with it. I do own A Blackdragon  recabled T5p I will have to give a listen with the Krell when I get a chance.
 I also find the T5p to be picky with some portable amps but sounds great directly out of My Dell laptop listening to CDs go figure.
Edited by bozebuttons
I go to buy a function generator to see how and when he clip. Like this I can measure the output power too...
Any recommendation for the generator ?
The amp run since 5 hours and he is getting to sound better !
