trident900fi Posted May 25, 2013 Report Posted May 25, 2013 I start to receive the components. I hope make it run in 2 or 3 weeks !
spritzer Posted May 25, 2013 Report Posted May 25, 2013 Here is how far I got until the next Mouser shipment: All the transistors are the originals and there are a lot of them.
T-Bird Posted May 26, 2013 Report Posted May 26, 2013 Nice! I would be interested in seeing your progress if you are up to it
trident900fi Posted June 3, 2013 Report Posted June 3, 2013 I just got the PCB ! As soon as I have a little time left, I can start the soldering job. If someone is interested, I have some board left
trident900fi Posted June 4, 2013 Report Posted June 4, 2013 I just got the PCB ! As soon as I have a little time left, I can start the soldering job. If someone is interested, I have some board left Hello Guys, Sorry, but all the left boards are gone...
kevin gilmore Posted June 7, 2013 Author Report Posted June 7, 2013 (edited) bombs away (ok, this is a mess) 1000uf 35v ls=5 dia=13mm 871-B41041A7108M000 35 .1uf 100v ls=5mm 80-R82EC3100DQ70J 14 4.7uf 63v wima 505-MKS24.7/63/5 7 470pf 500v ls 5.9mm 5982-15-500V470 4 39pf 500v ls 5.9mm 598-CD15ED390JO3F 2 220pf 500v ls 5.9mm 598-CD15FD221JO3F 2 mjf15030 863-mjf15030g 6 mjf15031 863-mjf15031g 4 heatsink amp board 532-531302B25 8 mpsa56 19 mpsa06 23 lsk389 2 relay 653-g5v-2-h1-dc24 2 op27 digikey 4 500 ohm pot 652-3299w-1-501lf 2 3 pin terminal 651-1729131 2 2 pin terminal 651-1729128 2 2 ohm 5 watt 71-cpf3-f-2 8 10 ohm 71-rn60d-f-10 16 25.5 ohm 71-rn60d25r5f 8 100 ohm 71-rn60d-f-100 4 221 ohm 71-rn60d-f-221 2 402 ohm 71-rn60d-f-402 4 475 ohm 71-rn60d-f-475 8 680 ohm 71-rn60d-f-680 8 825 ohm 71-rn60d-f-680 2 1k ohm 71-rn60d-f-1.0k 4 1.5 kohm 71-rn60d-f-1.5k 4 2.74k ohm 71-rn60d-f-2.74k 10 3.65k ohm 71-rn60d-f-3.65k 4 4.7k 71-rn60d4701f 1 6.19k ohm 71-rn60d-f-6.19k 2 8.2k ohm 71-RN60D-F-8.25K 2 33.2k 71-rn60d-f-33.2k 4 47.5k 71-RN60D-F-47.5K 2 1n914 4 1n4746a 78-1N4746A-TAP 1 1n4007 512-1n4007 1 1n5408 821-1n5408 4 Edited June 7, 2013 by kevin gilmore
Inu Posted June 7, 2013 Report Posted June 7, 2013 (edited) 4.7uF 63V WIMA = 6pcs 2 ohm (3W) = 71-cpf3-f-2 Edited June 7, 2013 by Inu
jwzhan Posted June 7, 2013 Report Posted June 7, 2013 Changed. The file is open to all for edit, so if anyone finds more error, feel free to correct it.
trident900fi Posted June 7, 2013 Report Posted June 7, 2013 Another alternativ for the 1000uF/35V, is the Nichicon UFG1V102MHM (Mouser: 647-UFG1V102MHM). A little bigger, but it's OK to put on the board. Here is a picture with the condensators fitted.
spritzer Posted June 11, 2013 Report Posted June 11, 2013 I got some parts in and it is almost ready.
jwzhan Posted June 12, 2013 Report Posted June 12, 2013 Very nice! How closely are the transistors matched?
spritzer Posted June 12, 2013 Report Posted June 12, 2013 Just basic matching, nothing more than that. Mostly because I didn't have enough to do any major testing and sorting.
bozebuttons Posted June 12, 2013 Report Posted June 12, 2013 Looking good,What caps did you settle on?
spritzer Posted June 12, 2013 Report Posted June 12, 2013 I used Panasonic FM's which pretty much the best you can buy at a sane price.
bozebuttons Posted June 12, 2013 Report Posted June 12, 2013 Looking forward to your impressions once you get it up & running.
PICaudio Posted June 12, 2013 Report Posted June 12, 2013 Zettler 24V Relay A2830-2C-24DS http://www.bgmicro.com/REL1086.aspx MPS8099 and 8599 (0.15) http://www.bgmicro.com/TRNMPS8099.aspx http://www.bgmicro.com/TRNMPS8599.aspx It is hard to pairing MJEs… MJE15030G(NPN) Lot:AFA50 hfe = 78 78 80 83 96 97 98 104 104 105 107 109 111 114 MJE15031G(PNP) Lot: AFB09 hfe = 228 234 238 241 242 252 253 257 260 262 I have the same problem MJF15030 (Lot: SPC05) HFE= 143 - 156 MJF15031 (Lot: SPB24) HFE= 246 - 257 -- o -- Rodrigo
Inu Posted June 12, 2013 Report Posted June 12, 2013 (edited) I am replacing these to 2SA1930 and 2SC5171. Edited June 12, 2013 by Inu
jwzhan Posted June 13, 2013 Report Posted June 13, 2013 someone over at a Chinese DIY site has a working KSA5 clone based on the schematic Kevin posted. He used his own boards, replaced mpsa06/mpsa56 with BC546/BC556, and changed the cap values a bit. He seems to like the sound (obviously.) Right now.. he is playing with different caps. Here is the link.
spritzer Posted June 13, 2013 Report Posted June 13, 2013 I didn't fare any better with the output devices but this amp will be as close to stock as is possible. someone over at a Chinese DIY site has a working KSA5 clone based on the schematic Kevin posted. He used his own boards, replaced mpsa06/mpsa56 with BC546/BC556, and changed the cap values a bit. He seems to like the sound (obviously.) Right now.. he is playing with different caps. Here is the link. Most of that doesn't make any sense to me. Rolling caps which look mostly vintage... why would anybody do that?
PICaudio Posted June 13, 2013 Report Posted June 13, 2013 I am replacing these to 2SA1930 and 2SC5171. Many thanks for this info, Is it possible that Krell had used transistors with these large differences of HFE? someone over at a Chinese DIY site has a working KSA5 clone based on the schematic Kevin posted. He used his own boards, replaced mpsa06/mpsa56 with BC546/BC556, and changed the cap values a bit. He seems to like the sound (obviously.) Right now.. he is playing with different caps. Here is the link. -- o -- Rodrigo
