Both Birgir and I have wanted one of these for quite a while, and they never seem to show up.
So with a little help from one of the members here we were able to reverse engineer this one.
http://gilmore.chem....rn.edu/ksa5.pdf
http://gilmore.chem....rn.edu/ksa5.jpg
still have work to do on the power supply.
All the parts are still available, but identical and compatible parts also available.
mpsw06 and mpsw56 and lsk389
I think this one is fairly cheap to do. And easy to assemble.
Single channel is 10 x 3.65 inches.
Single ended not really a HE6 killer, but balanced, a HE6 heavyweight for sure.
If you replace the servo opamp with opa445, then you can go up to +/-35v rails.
Then its definitely a HE6 killer single ended.
picture of the original
http://gilmore.chem....du/ksa5orig.jpg
single ended with +/-21 power supplies, it does 10 vrms into 4 ohms or more.
balanced 20 vrms into 8 ohms or more.
single ended with +/-35 power supplies, it does 16 vrms into 4 ohms or more.
balanced 32 vrms into 8 ohms or more.
  • Like 1
Hmm... How suitable actually would this be for speaker duties? Most likely it would require a considerable bump in heat-sinking. Maybe even some meatier resistors.
I could build one for computer speaker duties. Maybe get me a pair of those Hsu's.
The people at diy audio where i just posted this seem to think that Todd Eichenbaum
actually designed it. I don't know, none of the people i knew at krell are still there
so i have no way to verify.
As a speaker amp, you probably want the most efficient horns you can get.
Not a good idea.
Hmm... Maybe I had some mistakes converting vrms into power. In any case I still love my Dynalo and have a feeling that utility wise it would overlap with the KSA 5 (both being current happy).
Still too lazy (and afraid what you'll say about the wiring) to do a proper post at the DIY build thread.
The Dynalo and KSA-5 are similar is many ways but that is a very good thing in my book. I wouldn't try to use this for speakers though as the amp was never intended to do that. The PSU will not like it one bit too.
Huge thanks to Tom for his help on this and the reasons for me buying a HD-800 should be clear now. laugh.png It should be quite cheap to build as all parts or subs are available but the electrolytic caps should add up quickly. This run balanced at +/-35V will be a beast to reckon with...
Why, oh Why do you guys keep coming up with these great clone builds. I have subscribed and will be looking forward to this one. Especially since parts are actually available for a reasonable price.
The Q14 - Q23 thing has me confused ???
Looking at the pic of the board, dont see Q23.
Also what is the function of the relays and other components in the middle of the board, between the two channels?
Startup delay?
nice, I probably dont need the higher voltage balanced version, but maybe I should build it just in case =) saw it over at DIYA, should be fun, will make my own boards if need be, thanks for that Kevin!
http://gilmore.chem....du/dsc_0177.jpg
The blackgate caps and the dact are mikhail's handiwork.
here are the schematics for the 2 power supplies.
The first one is the original supply that tom owns.
http://gilmore.chem.northwestern.edu/ksa5psschemold.pdf
this is the newer version
http://gilmore.chem.northwestern.edu/ksa5psschem.pdf
I think we will be doing the new version.
I'm sure they sound different.
