I'm planning on getting a universal player within the next few months, so I can play dvd audio discs. Probably the Ayre DX-5.
Headphone rig only for now, so stereo only.
I noticed some dvd audio releases are advertised as a standard cd and dvd with 5.1 surround.
If the release does not specifically mention a high resolution stereo version too, will the surround mix not get sent to stereo correctly?
I want to avoid getting something if I can only listen in surround, basically.
Best solution for headphone listening is running the multi-channel output to a Smyth Realizer, that's a fantastic sounding setup for DVD-A.
Otherwise, I rip the DVD-A's on the PC, and downmix them there, using the right software, you can get a better sounding downmix than the standard DVD-A downmix, in my experience. Look up DVDA Explorer if you want to go that route.
Yes, you could always mix them down, but no, there's no promise that they will sound right. The problem is cancellation, which is most largely a problem with heavily processed modern music, or (artificially generated) electronic music, less so with classical and jazz.
I agree with the Smyth Realizer, even though I've never heard it -- it's going to try to maintain the essence of the surround mix in a stereo mix. There are other ways of doing it, of course. There was a column on the subject in ...Absolute Sound, I think?...several years ago. He did it the other way, too -- used an artificial surround enhancement to make surround out of stereo mixes.
The other thing you need to worry about is whether or not you are buying a DualDisc -- those were thicker than either CD's or DVD's, so didn't play in all players.
