luvdunhill Posted May 27, 2015 Report Posted May 27, 2015 It's better to use a rotary deburring tool to enlarge. 1 Quote
GeorgeP Posted May 27, 2015 Report Posted May 27, 2015 That psu is just one of many BH variants that I've drawn up over the years. 500V input caps and 450V output caps. You can get it through with some care (that's what she said.... ) but a drill does help. Just make sure to deburr... even the 1486? Quote
JoaMat Posted May 27, 2015 Report Posted May 27, 2015 (edited) / Edited November 11, 2015 by JoaMat Quote
GeorgeP Posted May 27, 2015 Report Posted May 27, 2015 (edited) What kind of press, Joachim? Avoiding the expense of PEEKs seems worthwhile (apart from the torque discussion). Edited May 28, 2015 by GeorgeP Quote
kevin gilmore Posted May 28, 2015 Report Posted May 28, 2015 (edited) I use a very small machinists vice like this https://www.southern-tool.com/store/wilton-super-precision-tool-makers-steel.php mine is about 40 years old, and even better built, no idea where I got it Edited May 28, 2015 by kevin gilmore Quote
GeorgeP Posted May 28, 2015 Report Posted May 28, 2015 This one looked really good... until I saw the price. Will try to find something similar under $100. Quote
n3rdling Posted May 28, 2015 Report Posted May 28, 2015 Lots of stuff here http://www.shars.com/products/toolholding-workholding/vise?limit=30&p=2&price=-100 1 Quote
JoaMat Posted May 28, 2015 Report Posted May 28, 2015 (edited) / Edited November 11, 2015 by JoaMat Quote
spritzer Posted May 28, 2015 Report Posted May 28, 2015 even the 1486? The 1486 is partially insulated so you just need the ceramic insulator for them. Better yet, use the KSA1156 where you can. Quote
arnaud Posted May 30, 2015 Report Posted May 30, 2015 So, it appears Justin Wilson knows about his stuff, a little bit... http://www.head-fi.org/t/439657/headamp-blue-hawaii-special-edition/7200#post_11647599 arnaud 2 Quote
spritzer Posted May 30, 2015 Report Posted May 30, 2015 Now you know why we keep increasing the clearance of the ground plane around the traces. The KGSSHV power supply was he biggest headache as there we have roughly 700V of raw DC floating around. My longest bit of troubleshooting was last summer, two months to find a phantom noise in one of my BHSE's. Came and went but was finally tracked down to the TV antenna causing a ground loop. 1 Quote
justin Posted May 30, 2015 Report Posted May 30, 2015 i thought it was an arc in the pic, but it was a whisker that i missed. had that whisker not been current limited by a 1M resistor, it would have most likely blown apart 1 Quote
kevin gilmore Posted May 30, 2015 Report Posted May 30, 2015 that's what Justin gets for using quality made in usa circuit boards. time to use the Chinese crap. Quote
Hifi Nutter Posted May 30, 2015 Report Posted May 30, 2015 The inside of that blue Hawaii looks amazing,never seen the lid off the Psu though,be interesting to look at that too,Think I would leave the covers off,make it more exciting tip toeing around it plugging the headphones in and out,joke Quote
skullguise Posted May 30, 2015 Report Posted May 30, 2015 i thought it was an arc in the pic, but it was a whisker that i missed. had that whisker not been current limited by a 1M resistor, it would have most likely blown apart Are cats doing your soldering now Justin? Good, and apparently lucky, find! Quote
dsavitsk Posted May 30, 2015 Report Posted May 30, 2015 that's what Justin gets for using quality made in usa circuit boards. time to use the Chinese crap. You wouldn't say that if you just had the day I had trying to track down the short(s) in a board. 1 Quote
arnaud Posted May 30, 2015 Report Posted May 30, 2015 i thought it was an arc in the pic, but it was a whisker that i missed. had that whisker not been current limited by a 1M resistor, it would have most likely blown apart I feel even luckier Quote
justin Posted May 31, 2015 Report Posted May 31, 2015 (edited) You wouldn't say that if you just had the day I had trying to track down the short(s) in a board. i've had one that i could never find even after knowing exactly which trace was shorted, and looking at it under a microscope. it had to be internal. kevin's idea of blasting it with high current did the trick i also had a board where I had paid for the flying probe testing, and a short was found - i could see where they used a blade to remove the short. However what they didn't do is test it a 2nd time, because there was actually a 2nd short on the same trace. I didn't consider that possibility so that one took me a while to figure out Edited May 31, 2015 by justin Quote
Ali-Pacha Posted May 31, 2015 Report Posted May 31, 2015 So, it appears Justin Wilson knows about his stuff, a little bit... http://www.head-fi.org/t/439657/headamp-blue-hawaii-special-edition/7200#post_11647599 arnaud I feel like you're debugging the path for whatever may happen to me when I receive mine Ali Quote
shellylh Posted March 8, 2016 Report Posted March 8, 2016 I was moving my setup around and unplugged all the cables without paying attention to how they were plugged in. Is there a certain direction that the umbilical cord needs to be plugged in? or can someone send me a copy of the instruction manual? Don't know where my manual is right now. Quote
Voltron Posted March 8, 2016 Report Posted March 8, 2016 On the Nate bhse, it only works one way. There is a male and female end. If it is the same on both ends I'm not sure how it could be directional. 1 Quote
shellylh Posted March 8, 2016 Report Posted March 8, 2016 On the Justin BHSE, there is also a male and female end. I am concerned about different rotation of the cord when you plug it in (it plugs in with a 3 by 3 grid). Perhaps I should look closer, maybe there are some grooves so that it can only plug in one way. Quote
n_maher Posted March 8, 2016 Report Posted March 8, 2016 ^^ What he said, there's only one way to plug the cords in on the BHSE, Shelly. There is also a key (and matching slot) on each connector receptacle pair so you can't get it wrong unless you apply serious anger and break something. 2 Quote
shellylh Posted March 8, 2016 Report Posted March 8, 2016 I just realized that. I guess I should've looked more carefully before posting. 4 Quote
skullguise Posted March 9, 2016 Report Posted March 9, 2016 Better safe than sorry, especially with a precious BHSE Quote
