boomana Posted May 26, 2009 Report Posted May 26, 2009 I think some people dropped out. Not sure if others have stepped in, though I would think that after it's heard at CanJam again, at least a couple people might realize how good this amp really is. Quote
feckn_eejit Posted May 26, 2009 Report Posted May 26, 2009 Should I sell: a) my car at least 3 of 6 guitars c) all audio equipment that is not strictly necessary d) my soul e) any combination of the above in order to get a BHSE? Quote
Asr Posted May 26, 2009 Report Posted May 26, 2009 ^^ And the amazing value that it represents, with the latest thinking from one of the greatest minds of our time! The BHSE is a masterpiece that will forever be unequalled! Hey Justin, any chance I could get the lesser of my next 2 orders for free? Quote
Hopstretch Posted May 26, 2009 Report Posted May 26, 2009 If you can get five grand for your soul, you've led a better life than I have. Quote
feckn_eejit Posted May 26, 2009 Report Posted May 26, 2009 If you can get five grand for your soul, you've led a better life than I have.i think i meant for d to fall under e, really........though i think someone did try to sell a soul on fleaBay once........... Quote
grawk Posted May 26, 2009 Report Posted May 26, 2009 Should I sell: a) my car at least 3 of 6 guitars c) all audio equipment that is not strictly necessary d) my soul e) any combination of the above in order to get a BHSE? yes Quote
Dreadhead Posted May 26, 2009 Report Posted May 26, 2009 I'm really looking forward to hearing this amp though I will not own one. Quote
feckn_eejit Posted May 26, 2009 Report Posted May 26, 2009 yesOK let's get rolling... anyone wanna buy a Pass Labs D1 (with 24/96 upgrade so CS8414, DF1704, 8x PCM1704, currently visiting its father for a checkup...) or a Sonic Frontiers SFT-1? Quote
Dreadhead Posted May 26, 2009 Report Posted May 26, 2009 Dude. It'd be cheaper to fly to CanJam and decide for yourself before hand. Quote
feckn_eejit Posted May 26, 2009 Report Posted May 26, 2009 Dude. It'd be cheaper to fly to CanJam and decide for yourself before hand.I may be partially joking...... plus I don't even have a pair of O2s......... and I'm deliriously happy with my X250.5-->Illusion ESC-1001-->SRD-X Mk.III/Pro rig....... Quote
boomana Posted May 26, 2009 Report Posted May 26, 2009 I'm really looking forward to hearing this amp though I will not own one. Didn't you hear it at grawk's meet? Quote
grawk Posted May 26, 2009 Report Posted May 26, 2009 The SRD-X/mk3 pro will be a great match with the blue hawaii Quote
feckn_eejit Posted May 26, 2009 Report Posted May 26, 2009 The SRD-X/mk3 pro will be a great match with the blue hawaiiNatch, but are there any Stax that are a shitty match with the BH? note to self: hawk SR-404s on HF, sharpish....... Quote
Hopstretch Posted May 26, 2009 Report Posted May 26, 2009 The SRD-X/mk3 pro will be a great match with the blue hawaii Here's Old Nick himself to see about that soul... Quote
grawk Posted May 26, 2009 Report Posted May 26, 2009 Err SRX of course. Anyway, yes there are lots of stax that sound bad with the blue hawaii, unless you get the normal bias jack too Quote
feckn_eejit Posted May 26, 2009 Report Posted May 26, 2009 Err SRX of course. Anyway, yes there are lots of stax that sound bad with the blue hawaii, unless you get the normal bias jack too waaaaaaaah waaaaaaaaaaaaaaaaaahhhhhhhh what, break off center pin, then ZAP!!!!!! Quote
Dusty Chalk Posted May 26, 2009 Report Posted May 26, 2009 (edited) Should I sell: a) my car at least 3 of 6 guitars c) all audio equipment that is not strictly necessary d) my soul e) any combination of the above in order to get a BHSE?Some combination of b & c, yes. Or perhaps you could talk to flecom about a second job. Can you run a mop? They're having a hard time finding people who want to run the mop, for some reason. I, unfortunately, only have 3 guitars, and none of any worth. Ditto "audio equipment". Certainly not enough to add up to a BHSE. Need to play win some scratchers. Edited May 26, 2009 by Dusty Chalk Quote
spritzer Posted May 27, 2009 Report Posted May 27, 2009 Natch, but are there any Stax that are a shitty match with the BH? Ehhhh no, and I've tried all the possible models except two. I miss mine badly and it's almost been a year since I sent it off to Justin. Lack of time, other projects and our crumbling economy are slowing down my plans to build my own versions so I'm stuck with the Egmont (soon to be fitted with some feedback) and the 717... :'( Quote
spritzer Posted May 27, 2009 Report Posted May 27, 2009 I would rate it on par with the SRM-T1 so not bad but not great either. It has a bit more extension then the Stax amp but it's also not as smooth with a slight edge in the midrange and treble. I'm not done with it as I'm going to add feedback (a cap and a resistor per phase) and swap out the plate resistor for the 6S4A's. The 47k/5W units run at 70-80 Quote
spritzer Posted May 27, 2009 Report Posted May 27, 2009 The PSU used by Rudi is an absolute turd, a simple voltage doubler and it runs at a much lover voltage (+/-260v) then I'm running the basic KGSS PSU at (+/-350v). I was pretty much stuck with the KGSS PSU due to space issues and that I wanted to use my 30$ R-core transformer which didn't have split secondaries. I could have used a similar PSU as Justin is using in the BHSE but that would be overkill in every sense. Now given the design and tubes used by Rudi he would have had to use two PSU's to be able to use any higher voltage then +/-260v given the limitations of the ECC83 input tubes. The ECC99 is pin compatible, can handle much more voltage but has less gain but I could live with it. It's also in current production, sounds great and I have a bunch on hand for use in the APL. The largest flaw of the Egmont amp circuit are the 6SN7 output tubes. These are almost the same as the 6CG7's used by Stax in their amps so have all the same issues. Not enough power or voltage handling (though there are higher rated versions of the 6SN7 available) plus they are far from cheap. The 6S4A is a much better fit with more power handling, higher voltage rating and they are cheap since nobody uses them. The biggest problem with the Rudistor amps is the bias supply. It's a fuckup of epic proportions with huge caps that aren't going to be kind on the resistive coating on the diaphragms. Quote
pabbi1 Posted May 28, 2009 Author Report Posted May 28, 2009 Birgir, if you are bored, I can send you a little project to tide you over... in the manner to which you have become accustomed... ;-) Quote
Elephas Posted June 15, 2009 Report Posted June 15, 2009 I sent an email to Justin: Can you give me an estimated delivery date for the Blue Hawaii SE? I must admit that the longer it drags on the more I want to cancel my order. I placed my order and a deposit in Oct. 2007. When you asked for full and final payment in Dec. 2008, I thought the amp shouldn't take too much longer to ship. Six months is a bit much, in my opinion, from collecting final payment and still no delivery and no communication. This kind of experience is similar to dealing with Single Power Audio. Quote
screaming oranges Posted June 15, 2009 Report Posted June 15, 2009 I sent an email to Justin:.... Ouch! For both sides too... Quote
n_maher Posted June 15, 2009 Report Posted June 15, 2009 The comparison to SP is a bit out of line but I understand the frustration of waiting. I think Justin is stuck in a tough spot with the BHSE. It'll likely be his least profitable product but requires the most care and attention and huge chunks of time. All I can say is hang in there, I believe the wait is almost over for the folks in the first batch. Quote
