Asr Posted March 9, 2009 Report Posted March 9, 2009 So how many watts will the BHSE pull from the wall? Quote
morphsci Posted March 9, 2009 Report Posted March 9, 2009 If Chuck Norris were an amp, Chuck Norris would be a BHSE!! Quote
grawk Posted March 9, 2009 Report Posted March 9, 2009 So how many watts will the BHSE pull from the wall? all of them Quote
guzziguy Posted March 9, 2009 Report Posted March 9, 2009 Really nice work Justin. Not bad at all for a kid. Quote
Jon L Posted March 9, 2009 Report Posted March 9, 2009 Wow. The phrase "The Few. The Proud" comes to mind. BTW, is that preamp output I see on the back, and if so, how does it sound? (poor audiofool trying to justify purchase in 'stat/speaker system) Quote
morphsci Posted March 9, 2009 Report Posted March 9, 2009 BTW, is that preamp output I see on the back, and if so, how does it sound? (poor audiofool trying to justify purchase in 'stat/speaker system) Loop Output Quote
grawk Posted March 9, 2009 Report Posted March 9, 2009 It says "loop out", so I'm guessing it's not a preamp out Quote
spritzer Posted March 9, 2009 Report Posted March 9, 2009 So how many watts will the BHSE pull from the wall? Something like 150-200w. In case you are wondering... this is a serious headphone amp. Quote
cclragnarok Posted March 9, 2009 Report Posted March 9, 2009 Something like 150-200w. In case you are wondering... this is a serious headphone amp. So about 2x ~ 2.5x as good (as a room heater) as my KGSS. Quote
luvdunhill Posted March 9, 2009 Report Posted March 9, 2009 Something like 150-200w. In case you are wondering... this is a serious headphone amp. meh. I'd guess 80W-90W (I don't know what the CCS are set at in this version, hence the range) Quote
Dreadhead Posted March 9, 2009 Report Posted March 9, 2009 If I ever design an amp I'm going to put a giant heat sink with a resistor that takes 1000w from the wall. More power is always better Quote
manaox2 Posted March 9, 2009 Report Posted March 9, 2009 If I ever design an amp I'm going to put a giant heat sink with a resistor that takes 1000w from the wall. More power is always better Great sound and keeps your coffee steamy. 3rd degree burns come to mind. I think MOAR POWAH should become a brand name. Quote
justin Posted March 9, 2009 Report Posted March 9, 2009 meh. I'd guess 80W-90W (I don't know what the CCS are set at in this version, hence the range) don't forget the filaments, power supply regulation, and transformer inefficiency Quote
luvdunhill Posted March 9, 2009 Report Posted March 9, 2009 don't forget the filaments, power supply regulation, and transformer inefficiency my guess still stands Quote
justin Posted March 9, 2009 Report Posted March 9, 2009 wat? the standard BH is 10W bias per tube 10W CCS x4 = 40W 10W EL34 plate x4 = 40W 1.6A x 6.3V x 4 = 40W voltage regulation = +15% transformer efficiency = +15% total = 166W then add in the -300V regulators, a couple watts for the +/-15V, and its easily 175W Quote
luvdunhill Posted March 9, 2009 Report Posted March 9, 2009 wat? the standard BH is 10W bias per tube 10W CCS x4 = 40W 10W EL34 plate x4 = 40W 1.6A x 6.3V x 4 = 40W voltage regulation = +15% transformer efficiency = +15% total = 166W then add in the -300V regulators, a couple watts for the +/-15V, and its easily 175W 80W-90W per channel, obviously Quote
