Quick question and likely an easy one, but it escapes me.
If one were to have a power meter on the front of their amp, say, like the D'Agostino Momentum, what would it be connected to? I assume across the power supply...or would it be across the output?
Thanks!
Gratuitous picture for fun.
The meter is a bias meter in the pic, not a VU meter.
Ah. I'm getting it. Depends on what you want to show, then, right?
Edit: Found the L'Amp
Other Edit: The D'Agostino site makes it actually sound more like a VU:
"...Despite its impressive output of 300 watts per channel into 8 ohms, the Momentum draws less than 1 watt of power at idle—or about one fifth of what a typical cell phone charger might require."
I dunno!
Edited by bhjazz
Current d'agostino products are similar to the krell sustaned plateau bias stuff.
So the meter is showing the amount of class A bias, as a cpu inside monitors
the input signal and calculates the minimum amount of bias to maintain class
A operation. At least until the thermal limits kick in.
Real Vu meters are logarithmic, not linear. They would be hooked up
directly to the output terminals.
These days there are fancy ways of doing stuff like this with hall effect
detectors on the outputs to measure real current, combine with
the voltage, run it all into a cpu and calculate real power.
Edited by kevin gilmore
