Bryston BHA1 Headphone Amp
This just in: PWD -> DSHA-1b -> LCD-2 fixed the noise problem with the Bryston. :)
Doug said it was best just to max the volume on the amp and use the volume control on the PWD, which works fantastically. Completely noiseless. This shit sounds bananas. In a good way. Not the best match for my JH13s, but I have other amps for them. With the LCD-2s, the DSHA smokes the Bryston like a pack of Kools.
Anyone with LCD-2s out there needs to give the DSHA-1 a serious listen.
Edited by cutestory
  • Replies 101
  • Views 45.8k
  • Noise cancellation of COMMON MODE noise happens wherever the phases of the signal are compared. If the phases are compared at the inputs, noise cancellation happens there. If the phases are compared a
  • No, it means that there should hardly be any difference at all. Which is very cool. Ooh, unless the output impedance is different running SE and BAL. People put WAY too much importance on Bala
  • Thanks for the explanations, all. It is much appreciated. My balanced cable came in and is now connected to my LCD-2s, and I'm enjoying it quite a lot, design issues notwithstanding. Semi-ignora
This just in: PWD -> DSHA-1b -> LCD-2 fixed the noise problem with the Bryston. smile.png
I don't know, the LCD-2 rev2 is a perfect match for my Eddie Current ZDT and I can still use the ZDT with custom IEM and no noise (I'm using PWD Mk1 DAC). I do like the rev2 a bit more than my original Rev1.
