cutestory Posted November 28, 2012 Report Posted November 28, 2012 (edited) This just in: PWD -> DSHA-1b -> LCD-2 fixed the noise problem with the Bryston. Doug said it was best just to max the volume on the amp and use the volume control on the PWD, which works fantastically. Completely noiseless. This shit sounds bananas. In a good way. Not the best match for my JH13s, but I have other amps for them. With the LCD-2s, the DSHA smokes the Bryston like a pack of Kools. Anyone with LCD-2s out there needs to give the DSHA-1 a serious listen. Edited November 28, 2012 by cutestory
HeadphoneAddict Posted November 28, 2012 Report Posted November 28, 2012 This just in: PWD -> DSHA-1b -> LCD-2 fixed the noise problem with the Bryston. Doug said it was best just to max the volume on the amp and use the volume control on the PWD, which works fantastically. Completely noiseless. This shit sounds bananas. In a good way. Not the best match for my JH13s, but I have other amps for them. With the LCD-2s, the DSHA smokes the Bryston like a pack of Kools. Anyone with LCD-2s out there needs to give the DSHA-1 a serious listen. I don't know, the LCD-2 rev2 is a perfect match for my Eddie Current ZDT and I can still use the ZDT with custom IEM and no noise (I'm using PWD Mk1 DAC). I do like the rev2 a bit more than my original Rev1.
