naamanf Posted February 14, 2012 Report Share Posted February 14, 2012 Having a handfull of Squeezeboxes in the house I was hoping to try my hand at DRC for my speaker setup. After working throurgh to creation of a filter with DRC and Inguz, it would seem Inguz doesn't work with the latest version of LMC. I could always try and run an earlier version, but I figures I would see what others have had sucess with? BruteFIR seems like another option but I am LINUX retarded and it looks to be a bit configuration intensive. Quote Link to comment Share on other sites More sharing options...
ujamerstand Posted February 14, 2012 Report Share Posted February 14, 2012 Have you tried other packages like drc-designer? I'm quite interested in this topic, just haven't had the time to dive in yet... Quote Link to comment Share on other sites More sharing options...
naamanf Posted February 14, 2012 Author Report Share Posted February 14, 2012 Have you tried other packages like drc-designer? I'm quite interested in this topic, just haven't had the time to dive in yet... I definitely could try that and run it through Foobar. Quote Link to comment Share on other sites More sharing options...
Grahame Posted February 14, 2012 Report Share Posted February 14, 2012 (edited) This has been on my to-do list forever. Now that the lounge setup is in a stable state, and I have a beefy enough server it may happen. No doubt you've read this thread (and the referenced threads) on the slim forum. I'd be interested in your progress. Edited February 14, 2012 by Grahame Quote Link to comment Share on other sites More sharing options...
TMoney Posted February 14, 2012 Report Share Posted February 14, 2012 Ha. Saw the title of the thread and thought you were talking about this: In any case, I'll be interested about hearing about your progress and impressions. Good luck. Quote Link to comment Share on other sites More sharing options...
naamanf Posted February 14, 2012 Author Report Share Posted February 14, 2012 (edited) This has been on my to-do list forever. Now that the lounge setup is in a stable state, and I have a beefy enough server it may happen. No doubt you've read this thread (and the referenced threads) on the slim forum. I'd be interested in your progress. Posted a question in there and it turns out my Inguz is working. It sounds horrible with the correction files I made but it does work. Now I just need to work on making a good correction filter. Edited February 14, 2012 by naamanf Quote Link to comment Share on other sites More sharing options...
ujamerstand Posted February 15, 2012 Report Share Posted February 15, 2012 How did you take your measurements? Quote Link to comment Share on other sites More sharing options...
Dreadhead Posted February 15, 2012 Report Share Posted February 15, 2012 http://www.cross-spectrum.com/measurement/calibrated_behringer.html They are awesome. Quote Link to comment Share on other sites More sharing options...
naamanf Posted February 15, 2012 Author Report Share Posted February 15, 2012 How did you take your measurements? http://www.cross-spe..._behringer.html They are awesome. I have a ECM8000, but without the calibration file. I might sent it to them to get the calibration done, or just purchase a calibrated one. I did the measurements with the Inguz sweep recorded through a Profire 610 using Audacity. Mic was placed to ear level. Quote Link to comment Share on other sites More sharing options...
Dreadhead Posted February 15, 2012 Report Share Posted February 15, 2012 Sounds like you did it right. I wonder what the issue was. I was thinking of giving DRC a shot like I do with headphones already but I'm lazy and the Behringer DEQ already has automatic room correction EQ built in so I just use that with speakers. Not going to be as good as full on DRC but pretty good. Quote Link to comment Share on other sites More sharing options...
naamanf Posted February 15, 2012 Author Report Share Posted February 15, 2012 Sounds like you did it right. I wonder what the issue was. I was thinking of giving DRC a shot like I do with headphones already but I'm lazy and the Behringer DEQ already has automatic room correction EQ built in so I just use that with speakers. Not going to be as good as full on DRC but pretty good. Yeah everything looked correct, but it was my first time doing the measurements and doing the correction filter file. Maybe I got something backwards, which would explain the sound it gives. Or maybe I just need to suck it up and get better software for the correction. Quote Link to comment Share on other sites More sharing options...
Dreadhead Posted February 15, 2012 Report Share Posted February 15, 2012 Since I am doing the math myself I always check to see if my irfs cancel out as expected etc. Fancy software should not be required though it may make the process less painful (eg with calibration etc.) you may want to look at room eq wizard as you can get the irfs etc from it but it takes in calibration files and is free. Quote Link to comment Share on other sites More sharing options...
naamanf Posted February 15, 2012 Author Report Share Posted February 15, 2012 Since I am doing the math myself I always check to see if my irfs cancel out as expected etc. Fancy software should not be required though it may make the process less painful (eg with calibration etc.) you may want to look at room eq wizard as you can get the irfs etc from it but it takes in calibration files and is free. I'll give that a look. My math isn't so great, calculating the area under a curve is about as far as it goes. Quote Link to comment Share on other sites More sharing options...
ujamerstand Posted February 15, 2012 Report Share Posted February 15, 2012 http://www.cross-spe..._behringer.html They are awesome. Woah, these ARE awesome. What about ADC? What kind of fancy ADC are you guys using? Quote Link to comment Share on other sites More sharing options...
naamanf Posted February 15, 2012 Author Report Share Posted February 15, 2012 Woah, these ARE awesome. What about ADC? What kind of fancy ADC are you guys using? I'm using what ever is in the Profire 610 Quote Link to comment Share on other sites More sharing options...
ujamerstand Posted February 15, 2012 Report Share Posted February 15, 2012 Cool. I was originally going to get a cheap USB Interfaces like the Roland UA-1G. Looks like I might want to take a look at these a little more before I get one off the shelves. Quote Link to comment Share on other sites More sharing options...
naamanf Posted February 18, 2012 Author Report Share Posted February 18, 2012 (edited) After having mediocre success I came to the conclusion that A) I need a better Firewire card B ). will probably have to suck it up and purchase Audiolense. The licensing seems to be a bit crappy which makes it a hard pill to swallow, but if it works I think it will be worth it. Edited February 18, 2012 by naamanf Quote Link to comment Share on other sites More sharing options...
ujamerstand Posted February 18, 2012 Report Share Posted February 18, 2012 How did your system measure after applying drc? Quote Link to comment Share on other sites More sharing options...
naamanf Posted February 18, 2012 Author Report Share Posted February 18, 2012 How did your system measure after applying drc? You can't really measure it after the DRC since it is a filter. Well I guess I could make a sweep .wav and measure that. The filter I was able to create sounded like I was in a cave. Not good at all. The corrected .wav I made with Audiolense was much better but still not prefect. I think the crappy Firewire card is keeping it back. Should have a new one tomorrow. Quote Link to comment Share on other sites More sharing options...
ujamerstand Posted February 18, 2012 Report Share Posted February 18, 2012 Yeah, that's what I'm talking about. Getting some before and after measurements can tell you lots about what's going on. Like here. The cave sound sucks though, but I'd keep on trying other free alternatives before buying audiolense. Quote Link to comment Share on other sites More sharing options...
