kevin gilmore Posted March 8, 2012 Author Report Posted March 8, 2012 http://gilmore.chem.northwestern.edu/blackholebd.jpg The critical stuff fits. Now on to massive parts ordering binge.
fierce_freak Posted April 28, 2012 Report Posted April 28, 2012 Did you get your massive parts orders in?
kevin gilmore Posted April 28, 2012 Author Report Posted April 28, 2012 Yep, that one is virtually done too. I've been spending time on other stuff, but the prototype definitely works. And works well.
ujamerstand Posted June 13, 2012 Report Posted June 13, 2012 Any more progress in this area? I'm in the market for a nice and cheap instrumental amp.
kevin gilmore Posted June 13, 2012 Author Report Posted June 13, 2012 (edited) just have not had the time to test the final version. i can give you the board layout, have a few made and test. Biggest problem is that i'm moving my lab beginning of august, and i'm working 10 hour days in prep. Plus the stax mafia seem to be doing every possible electrostatic tube amp at the moment, all at the same time. Edited June 13, 2012 by kevin gilmore
ujamerstand Posted June 29, 2012 Report Posted June 29, 2012 So... How do we mount the chip to the sink? Drill two holes on the Ohmite sinks and screw it on?
kevin gilmore Posted June 29, 2012 Author Report Posted June 29, 2012 Buy the ohmite clip that is designed for the heatsink You also need a thermal insulator because the tab is Electrically hot. Will post the part number later.
kevin gilmore Posted June 29, 2012 Author Report Posted June 29, 2012 this is the mouser part number 532-CLP212G
ujamerstand Posted June 30, 2012 Report Posted June 30, 2012 Great! Will add it to my BOM. Also, what's the bjt between the output transistors?
jose Posted October 24, 2018 Report Posted October 24, 2018 I'm sorry to rescue this old thread. I've seen some schemes in the Stax mafia circuit boards but I don´t know if this ampli step finally "production". The fact is that I would not mind doing one of these amps and maybe someone else is attracted to the proyect.
kevin gilmore Posted October 24, 2018 Author Report Posted October 24, 2018 The company that made the output transistors went out of business
jose Posted October 25, 2018 Report Posted October 25, 2018 Do you mean OPA541? Mouser has stock (OPA541AP) from TI. OPA541AP
spritzer Posted October 25, 2018 Report Posted October 25, 2018 No, the opa is an IC, not the transistors Kevin referred to.
jose Posted October 25, 2018 Report Posted October 25, 2018 (edited) Oh I'm sorry I was looking at this scheme and I thought it was about that Opa. I guess it's a dead end. Edited October 25, 2018 by jose
spritzer Posted October 25, 2018 Report Posted October 25, 2018 Wasn't that the pile of shit Ray did?
jose Posted October 25, 2018 Report Posted October 25, 2018 1 hour ago, spritzer said: Wasn't that the pile of shit Ray did? I'm not sure if that's Ray's amp. I have not found documentation about the Blackhole on "Stax mafia circuit boards", only references to the dark/dork star.
kevin gilmore Posted October 25, 2018 Author Report Posted October 25, 2018 (edited) that was ray's darkstar amp. the blackhole is something different. the blackhole uses a national semiconductor driver chip lme49830 and a pair of alf16P/alf16N semisouth fets for the outputs. You can probably substitute something else for those parts, including bipolars, as the board has options for that too, but I never tested that way. the darkstar sounds absolutely miserable, and these days has stupidly large voltage swings guaranteed to set just about anything on fire. the blackhole is suitable as a small speaker amp. Edited October 25, 2018 by kevin gilmore
