kevin gilmore Posted December 17, 2011 Author Report Posted December 17, 2011 (edited) Yes of course i can mill down the heatsinks. I want something that others can build with no trouble. The heatsink fins need to be vertical to be efficient, so that ohmite thing probably won't work, but i can buy a couple from mouser next order to see. The other problem is that the lme49830 part would sit very low on the heatsink so the clips probably don't work. Which is why the original part i picked works poorly as the supplied snap clip only touches half of the part. Edited December 17, 2011 by kevin gilmore Quote
cobra_kai Posted December 19, 2011 Report Posted December 19, 2011 Been doing a bit of searching for a heatsink, it seems that Aavid heatsink is the reference one that national lists. I found a site with a picture of a heatsink that looks really good but haven't been able to find the part number for it. Here is the picture though: Quote
n_maher Posted December 19, 2011 Report Posted December 19, 2011 Doesn't look like it'd be very easy to attach a TO220 device to that heat sink. Not saying it couldn't be done but the picture clearly shows something pretty different. Quote
cobra_kai Posted December 19, 2011 Report Posted December 19, 2011 (edited) lme49830 is not TO-220 http://www.ti.com/li...nk/lme49830.pdf Anyway I emailed the guys who make the thing in that picture to see if they are willing to tell me the part number. Fingers crossed they are nice... Edited December 19, 2011 by cobra_kai Quote
kevin gilmore Posted December 19, 2011 Author Report Posted December 19, 2011 That is the heatsink i want. Have not figured out what it is yet. Quote
cobra_kai Posted December 19, 2011 Report Posted December 19, 2011 I got a response from them about the heatsink, apparently the heatsink itself is manufactured in China and is rather large, then they must mill it down to size. See this image: They said they could sell it to me machined down. I'll ask them how much it would be for the same size they are using, in quantity of ~100. Quote
JoaMat Posted December 19, 2011 Report Posted December 19, 2011 Heat sink for LME498**: http://www.aptaudio....PA_Parts_1.html Quote
kevin gilmore Posted December 19, 2011 Author Report Posted December 19, 2011 why does the simple stuff have to get so complicated sometimes. Quote
cobra_kai Posted January 19, 2012 Report Posted January 19, 2012 Been spending a bit of time on diyaudio recently and came across a very similar project to this: http://www.diyaudio.com/forums/solid-state/196932-wire-amp-class-ab-power-amplifier-based-lme49830-lateral-mosfets.html It has one feature that I particularly like - the ability to have a regulated power supply for the lme49830 front end and choose between the same for the output transistors or a separate unreg supply. I haven't spent the time to read through and see what heatsinks people are using but there may be some info in there. Quote
kevin gilmore Posted January 20, 2012 Author Report Posted January 20, 2012 (edited) I did eventually decide on the ohmite heatsinks, some are on their way to me. Board size increased a bit to 3.6 x 3.6 inches. the idea of multiple power supplies is something i'll think of, not so hard to do, but really i'm doing this for a headphone amp, and don't need to run the thing at silly voltages and powers. (not the same heatsinks that the wire uses) The alfet parts sound so much better than the irf parts... Edited January 20, 2012 by kevin gilmore Quote
MASantos Posted January 20, 2012 Report Posted January 20, 2012 While the primary use could be headphone duty, it would be nice to have the option to scale up easily. this wouldn't add much to the board cost. Quote
kevin gilmore Posted January 21, 2012 Author Report Posted January 21, 2012 current version with the dual power supplies, i still think its a bit silly. Virtually 100% ground plane. http://gilmore.chem.northwestern.edu/blackhole2.jpg Quote
kevin gilmore Posted January 22, 2012 Author Report Posted January 22, 2012 sillyness continues http://gilmore.chem.northwestern.edu/blackhole3.jpg now compatible with both kinds of fet layout GDS and GSD also usable with darlington bipolars and either lme49830 or lme49810 Quote
ujamerstand Posted January 22, 2012 Report Posted January 22, 2012 what kind of output voltage could you achieve with dual power supplies? Quote
cobra_kai Posted January 22, 2012 Report Posted January 22, 2012 (edited) sillyness continues http://gilmore.chem..../blackhole3.jpg now compatible with both kinds of fet layout GDS and GSD also usable with darlington bipolars and either lme49830 or lme49810 lookin good what kind of output voltage could you achieve with dual power supplies? lme49830 can handle +/-100, as can the alf16. You won't be able to swing all the way to the rails so maybe +/- 95 on the output theoretically. No idea what you would need that much voltage for, and it probably wouldn't work on this pcb as capacitors for that voltage would be a lot larger. Something in the +/-40 volt ballpark should be adequate for almost all speakers I would think. Edited January 22, 2012 by cobra_kai Quote
ujamerstand Posted January 22, 2012 Report Posted January 22, 2012 I see. I thought you could increase the voltage in the second stage for some reason... Quote
cobra_kai Posted January 22, 2012 Report Posted January 22, 2012 It makes it so you can use a really nice linear regulated supply for the lme 49830 and an unregulated supply on the output. So you don't have to have a massive regulated ps if you want to power speakers. Quote
kevin gilmore Posted January 22, 2012 Author Report Posted January 22, 2012 (edited) all the capacitors are 100 volt rated. possible output transistors sets usable at full voltage (really, don't do this +/-40V is already more than overkill) alf16n20w/alf16p20w 2sk1058/2sj162 BUZ901/BUZ906 2sk1529/2sj200 MN2488/MP1620 MJH11020/MJH11019 Edited January 22, 2012 by kevin gilmore Quote
ujamerstand Posted January 22, 2012 Report Posted January 22, 2012 It makes it so you can use a really nice linear regulated supply for the lme 49830 and an unregulated supply on the output. So you don't have to have a massive regulated ps if you want to power speakers. Ahh, I see. Got it. Quote
MASantos Posted January 23, 2012 Report Posted January 23, 2012 In the wire amp thread over at diyaudio they got best results in simulation when feeding the Lme with +10v than the output stage. This is quite simple with a regulated front end ps. There seems to be a shortage of lateral mosfets at the moment because of the floods in Taiwan, so this might be difficult to build in the next few months. Quote
cobra_kai Posted January 23, 2012 Report Posted January 23, 2012 Was there any discussion on the amount of power that can be dissipated with them? The datasheet claims 250 watts in the T0-264 package but I am a bit skeptical of that. Quote
kevin gilmore Posted January 23, 2012 Author Report Posted January 23, 2012 There is a shortage of all sorts of transistors these days, and the floods in taiwan probably influence this very little, who knows. Its a massive pain in the ass to source parts these days. Quote
MASantos Posted January 23, 2012 Report Posted January 23, 2012 Was there any discussion on the amount of power that can be dissipated with them? The datasheet claims 250 watts in the T0-264 package but I am a bit skeptical of that. There's a spreadsheet somewhere in the first pages with a wide selection of ps voltages and respective power output at different loads. According to it, the combination could feed over 300w into speaker loads with sufficient heatsinking. Quote
luvdunhill Posted February 18, 2012 Report Posted February 18, 2012 (edited) Combine 4 channels with my balanced preamp, and have one serious kickass thing guaranteed to drive anything, so, can't you drive this from a balanced input signal using a single board? If so, I'd take the two prototype boards. edit: nm, it's input voltage is too low for my application. Edited February 18, 2012 by luvdunhill Quote
jezz Posted March 6, 2012 Report Posted March 6, 2012 Does anyone know if the Exicon ECW20N20-Z/ECW20P20-Z are rebranded ALF16N20W/ALF16P20W? I've read through the datasheets and they report a few slightly different characteristics (Ciss, Coss, Crss, Ton, Toff), but are otherwise identical down to the unit price. If they are rebrands, they could be another source for the ALF16 200V parts, which appear to be unobtanium. Newark still has a few 160V parts at least. Quote
