high-amp
Members
  • Posts
    4
Profile Information
  • Gender
    Not Telling
Recent Profile Visitors
666 profile views
high-amp's Achievements
Newbie
Newbie (1/6)
0
Reputation
  1. The 2sc4686a is available from http://www.sh-halbleiter.de/en
  2. Here the lost constant voltage source.
  3. Hi crappyjones123 send me your resistors and I will see what I can do for you. Hope my response was fast enough for you. ok?
  4. To all the owners of a transistor amplifier V3.0 from http://www.high-amp.de out there in the world. Here is a support how to update your amplifier to the version 4.0 that will be coming out soon. The items below are refered to the following schematic: http://high-amp.de/html/transistor_v3_schematics.html - replace the four resistors R07x and R08x with 51K/1W resistors to increase the current in the second stage to 4mA - replace the two resistors R11x with 200 ohm resistors to increase the current in the last stage to 15mA - replace the resistors R56, R57 by a constant voltage source as shown below (one per chanel) - If you are using the 2SC5466 in the last stage replace it by the 2SC5353 (Q06x). The 2SC5466 can not handle 15mA because of the nonlinear hfe-curve above 10mA (bad performance especially in high frequencies, missing resolution). What do you have to expect from the update? You will improve your amplifier significant to a very fine resolution over the complete frequency range with very deep and structured basses and an excellent reproduction of high frequencies. I would warmly recommend to you to perform this update. You won't regret.
